CLUTCH PROBLEM! Please HELP!
Discussion in 'Motorized Bicycle General Discussion' started by Blackrain2012, Aug 16, 2010.
  1. Blackrain2012
    Blackrain2012 New Member
    Aug 12, 2010
    36
    Ok, see if you can help me out. I have been having clutch probs since i got this bike:
    My clutch is either stuck in the engaged position or the disengaged position.
    -if i loosen the flower nut 1 more notch, the clutch will be stuck in the engaged position
    -if i tighten it too much, the clutch will be stuck in the disengaged position.
    -I have spent hours testing each notch until it was too tight or too loose, but there is perfect position.
    -is there anything guaranteed to work? if there is ill do it
    I feel like this
  2. Venice Motor Bikes
    Mar 20, 2008
    6,174
    That doesn't make sense... you should be able to adjust the clutch to grab when the hand lever is 'out' & still be able to pull the lever 'in' to disengage the clutch.
    Post some pics of what you've done.
  3. DudeZXT
    DudeZXT New Member
    Jun 20, 2010
    115
    Like he said.
    You should be able to adjust the cable for fine adjustments...
  4. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
