Chain issues
Discussion in 'Motorized Bicycle General Discussion' started by N8dogg, Jun 7, 2010.
  1. N8dogg
    N8dogg New Member
    Apr 25, 2010
    47
    I got a manic mechanic 40 t sprocket/ adapter and I cannot get my chain to fit . it was perfect with the 44 but I am in the middle of it being to small where it wont fit or too loose where its almost falling off. It works but is too loose and just about ready to fall off when I pin it. I put the tensioner all the way up and my wheel as far back as possible and its still too loose. I tried taking out another link but then its too ****ing short so I bought a new chain and am back to square 1. If the tensioner was higher it would be perfect but I am stumped. I read about a couple tensioner mods but before I try something I might not be able to do is there anything I am missing to try to get it tight again? My cruiser is a crazy size I have just about had to rig everything I have done with the bike
  2. Patr1ck
    Patr1ck New Member
    Apr 15, 2010
    213
    Try sliding the tensioner bracket back along the bike frame to tighten the chain or forward towards the motor to loosen the chain.
    Pat
  3. N8dogg
    N8dogg New Member
    Apr 25, 2010
    47
    the only thing is I drilled a hole through the tensioner and frame so that really isnt a option. I wouldnt want to drill another hole
  4. Patr1ck
    Patr1ck New Member
    Apr 15, 2010
    213
    Do you got a welder?
  5. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
  6. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    17
    Have you tried a half link?
  7. N8dogg
    N8dogg New Member
    Apr 25, 2010
    47
    thanks for the link If I can't figure it out I will give that a shot
    No, I thought you always have to take off the bottom links which takes 2 off??
    No welding skills
  8. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    Well basically, on the chain you have the big and small links. Instead of using the big master link to connect 2 small links, you can connect a big link to a little link, meaning you can get a more acurate size.
  9. N8dogg
    N8dogg New Member
    Apr 25, 2010
    47
    I tried putting a link back on and couldnt get it to work. Any advice on how to put it back on successfully?
  10. GearNut
    Aug 19, 2009
    5,105
    Chains can only, safely, be re connected with a half link or a master link.
    I have seen other shade tree methods, but they have all failed in short time.
  11. Patr1ck
    Patr1ck New Member
    Apr 15, 2010
    213
    What is a half link?
    Pat
  12. Mind_Reader7
    May 1, 2010
    393
  13. GearNut
    Aug 19, 2009
    5,105
  14. Patr1ck
    Patr1ck New Member
    Apr 15, 2010
    213
