I've got a couple of 5/8", 11 tooth centrifugal clutches on my bench and an adapter plate if you want to try that. Go to My Albums "From Barry's Shop" to see the plate.
First off, my apologies if this is in the wrong forum, or has been covered elsewhere, but I've been searching, and have not been able to find it.
I'm a bit confused about the CVT choices out there. I've got a Predator 212, (older Ver. if that matters) and I'm looking at all the choices out there. On eBay, there are some that are as little as $114, and others as much as $249! I know the general rule; "You get what you pay for" usually applies, but then I found yet another website GoKartsUSA, and they've got a "special" cvt, with what they call an "adaptor" for the predator engine's offset shaft. Since the lower priced ver. represents 10% of my monthly income, (disabled Veteran, on a VERY fixed income), I cannot afford to make mistakes.
I guess my first question is obvious; which cvt should I buy? I am going with a stock build, since I'm a newb at this. and secondly I'm in Puerto Rico and local group support is limited, as is the availability of parts, unless I order online.
If I do eventually remove the gov. I'll prob only go so far as to change out the flywheel, but leave the rest stock. As far as my power needs, you could say they are modest; I'm a laid back cruiser kind of guy, and even though we've got some hellatious hills here, I won't be needing to power up them too fast, because they're most often accompanied by sharp turns. On the straights, I'd be happy cruising about 45 & seeing the sights, but to have a burst of speed in an emergency would not be unwelcome. With my "Power needs profile" stated, what would be the suggestion on a cvt and chain size... I've in mind, building a stretch frame cruiser, with both gas and pedal power, so true moped. I'm looking at either a Worksman wheel, laced to a dual hub, for chain drive on both sides, or a used moped wheel, that has the same setup already on it.
My next question is about that website; gokartsusa... I've not heard anyone "talk" (write) of them, so I don't know if they're reputable, in providing the goods purchased, OR if what they're saying about a "special" adapter needed for the HF Predator 212 shaft.
That page is here:
http://gokartsusa.com/Comet-TAV2-GTC-Torque-Converter-Predator.aspx
I was going to remove the gov and flywheel, but the flywheel is stuck on harder than I am comfortable with beating on it, so I'll leave it on for now...
Any and all advice on this subject would be most welcome, just contact me. Thanks to all, in advance!
Mac-
