The mag rotor is held in time by a woodruff key. If the key is missing or somehow gets sheared, even partially, it will definitely affect the ignition timing.
A very common error in rebuilding these engines is installing the rotor backwards, or inside out on the shaft. The rotor will go on either way and if one does not mark the outside face of the rotor with a marker or whatever, it is all too easy to re-install it backwards. A backwards rotor will also put the timing off.
If the rotor was not marked before disassembly, you can verify that it is correct this way:
With the magnets setting horizontal (left to right) the keyway will be in the 1 o'clock position.
If the keyway is in the 11'oclock position the rotor is backwards.
Why on earth the Chinese couldn't machine the keyway to be in the 12o'clock position is beyond me. If they did then it would not matter which way the rotor fits on.
