Andy,
Don't give up. There are thousands of these little motors out there running like a clock. There is likely some little thing you are missing. Have you tried finding someone with experience with small two stroke engines to help you. There are so few systems there it can't be anything complicated.
Your description sounds like it is rich. Have you tried shutting the fuel valve off when you get it running to see if it will start running better as the fuel is depleted?
Jim
Maybe it is a float issue. If I hold the primer button in, it takes about four seconds for the fuel to start flowing out around it. Does that sound correct?
andy b.
hey so im kind of a noob 2 motors/ motor bikes, does it matter whether the clutch is installed because my clutch does not have any affect, is there a video on how to install it? thanx
Evan R
Sorry man, but the primer button does not let any air out of the float bowl.
Andy,
I just saw those pics and notice the spark plug, you should try replacing stock parts 1 by1 while trying to start after exchanging 1
(I.e use stock sparkplug instead and try to start, fail to start then put the new one back in and replace another part etc etc
Evan
