broke motor stud due to a offroad trip
baadboy
90
tulare cal
ok today went for a 10 mile ride when i got pulled over by a chp he said nice bike BUT i cant have u on this road for ur own safety ur fine if u ride on the farm side roads so i did but as i was got down the dirt road it got muddy no big to me but my started to shake like i bent my rear sprocket so when i could stop i a dry area ii ad and both my rear motor stud where gone
the bike it on is a gt2 and i grind moumt so there is no gaps between mounts ant the bars the motor is a Grubee StarFire GT-4 love the bike and the motor every thig fits good
my problem is 1 how to get the stud out that are left and how do i keep this from happen again
pic as soon as i get my cam back from my kid :-||
DaveC
969
Boise, ID
It would depend on how deep in it's broken. Standard remedy its to put a cut-off wheel in a Dremel and cut a slot in the broken stud and use a screw driver to back it out. You might have to cut slightly into the engine case but there's really not a problem with that.
Then try to find bolts to fit. They need to say 8.8 or 10.8 on the head of the bolt with the 10.8 bolt being the better of the two but an 8.8 is much better steel than the stock Grade 1(if that) Chinese bolt.
One of the first up-grades I got was the Sick Bike Parts bolt set and the head stud set. And if you don't have a Metric tap set you should get one. I have found the holes are not tapped to the bottom of the holes. And there is variance in the head studs. My original head studs were *slightly* undersized. Not only that the stud had the two different thread spacing. Top was M8 1.25 and the bottom was M8 1.00. I had to tap the holes, though. The SBP head studs were just enough larger than the stock holes they would not go in more than 1 thread.
A tap set from Harbor freight for a 40 piece set is just under $12 and they are of a much better quality than they used to be. For $12 it's a bargan.boogy1a
DaveC
969
Boise, ID
Yeah, I've had the same problem except I lost 3 and had 1 break, all the stock stuff. Since I changed to the 8.8 bolts I've had no troubles. You have to carefully measure the length needed so that they are not too long or short. The torque from accelerating tries to pull the motor and the sprocket closer together, twisting the motor in the frame. The stress on those tiny weak studs is something else, especially the one's in the back.
But, yeah, cutting a slot in the broken stud is the way to go.
Jul 15, 2009
594
waukegan IL. U.S.A.
Once you get old studs out , i would drill out old thread and heil coil engine case to 1/4-20 . You can get heli kit at most good auto places or hardware store. Pretty simple and the larger size bolt is much stronger. Good luck.
BarelyAWake
7,194
21
Maine
The slot w/a dremel is a good 'un if it's at least flush, 'nother trick is a reverse drill bit (the lands go the other way), often when using a bit like that it'll back the stud out itself once ya get in there a lil bit. If yer gonna one size over the studs, there's no need for a helicoil as ya can jus' tap the aluminum block (helis are great if ya want/need the same size fastener) - but if ya do decide to heli/drill/what have you - mark the drill bit w/a bit of tape as a depth gauge so ya don't drill too deep.
My fave trick is to take a nut and place it over the sheered off stud & zot it there w/a welder - making a "bolt" jus' good 'nuff to get the busted stud out. If you don't have a welder, it's easy 'nuff to to bring the motor to w/e shop has one (car exhaust places for example) and it's such a simple, quick job they'll not charge ya much ;)
I did wanna mention however - I dunno if your "broke motor stud due to a offroad trip" is the cause, I've pounded the snot outa mine off road w/o problems, even dumped it a coupla times... might wanna double check the fit when ya get it back together :)
matthurd
817
manchester NH
not sure about where you live but in MA at autozone you can rent a tap kit for free, you need to put down a $90+tax deposit in case you never come back, but once you bring it back they give you your money back.
as for removing the studs they make extractor bits for drills, maybe home depot has some, you could check that out.
chances are the threading for the stud mounts are garbage, retap it to the next mm up or the next barely larger sae size.
goood luck.
baadboy
90
tulare cal
well just got in to the tear down looks to me like cheep studs as 4 he fit when i put it together there was no bent stud i took my dremel and smooth out the inside of the mounts so there was no air room between the bar and the mounts this motor is only about 3 weeks old to me just got broken in .cs.
baadboy
90
tulare cal
im out of luck 4 a quick fix was pulling off the cluch cable a the head o the bolt twisted off so now need a to fix that as well grrrrrr
baadboy
90
tulare cal
well i got the studs out with a dremel cutting wheel and a flat head but just a question there was only about 10 to 12 threads in the motor is that right ? or do i need to tap it out to a few more threads i know i need stronger studs
baadboy
90
tulare cal
OK was just screwing a round this morning and had 2 extra head bolts and a 2extra rear mounts and they work 4 now till i get some money up to fix it right
baadboy
90
tulare cal
Watch out gremlins come in three's!!! Take some deep breathes(maybe a cold one ) then just take your time ,do the ness. Prep and youll get it right.
Everybody goes thru this kinda stuff.
got all part to fix bike yesterday (the right way) went out 4 a ride with buddy thank we where on the home 12mile in the county and my frame broke ur right they come in 3s on top of that my kid got thrown in a pool with my camera in her pocket so no pic 4 while
GearNut
5,104
11
San Diego, Kaliforgnia
WoW man! I guess when it rains it pours for you eh? I am sorry to hear of all this misfortune for you.
Let us know how build #2 goes? And good luck with everything!
baadboy
90
tulare cal
I like the looks of that bike. It's just like my Atlas, only it gas gears to play with.
Hopefully it will hold up to the strains of an engine.
well into the gears im looking at the hd hub off my gt2 fits a geared bikes with no strain on the frame by pulling it outwards
