kdaddy1980
Im putting a jackshaft on my new project, its a huffy sante fe cruiser. i wanted to put rear disk brakes on it because im going to be going a lot faster with my jackshaft kit.
I bought this disc brake kit from a guy out of Cincinnatti, he said the disk would bolt to the sprocket somehow. The sprocket has extra holes which look like the are drilled correctly for the disk to mount on but they are not placed the same. To fit, they would have to be drilled or ground out. But, even if the holes lined up the disk would be too close to the sprocket for the caliper to fit in between them. So, i thought about just cutting the outer portion of the sprocket off and then mounting the disk to the sprocket. the disk would have to be aligned fairly well once mounted with the rubber sandwich for the disk not to hit the pads, there is only a little over 1/8" gap between the pads.
A wheel with a disk brake hub is 80 bucks, and if i wanted to just buy the hub it would be even more.so i spent 35 bucks on this contraption and im still contemplating on how exactly it will mount.
the threads of the mounting nut fit right onto a rear hub where the cassette screws on. my front fork will fit a rear hub and i could build the wheel around it for the front but my fear is that if this thing breaks, and locks up on me (on the front) most likely im gonna be ejected over the handlebars and be lucky enough not to be ran over by a car. but if it was on the rear it would probly just skid to a stop or maybe slide out, but id rather that then be tossed in the air 20 feet or so.
suggestions? thoughts? opinions? do you think there is any way im going to get away with not buying a new wheel or hub for it? what if i could thread the left side of the rear hub and screw it right on, i dont know of anyone with capability of doing that but it seems like it would be a simple solution.
