blew a tube. gah
Discussion in 'Motorized Bicycle General Discussion' started by a.graham52, Aug 15, 2014.
  1. a.graham52
    a.graham52 New Member
    Nov 22, 2013
    232
    went to ride my bike to the store tonight. didnt make it 5 ft before i found my rear tire flat. dismounted the rear tire and pulled the tube off without removing the whee. found and patched the hole with the slime brand kit. put it all back together, pumped it up to 55psi and less then 2 minutes later... WhAM. total blow out while just sitting there. good news is it wasnt my patch that blew out.
  2. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Ouch!! That can happen tho... just good thing you weren't on it and going close to 40mph when it blew... But hey... at least your patch held...
  3. a.graham52
    Nov 22, 2013
    232
    New tube. Got a Michelin brand with the weird valve stems. Also upgraded my rear brake shoes since the walmart oems are marshmallows.
  4. maniac57
    Oct 8, 2011
    4,486
    The best brake pads are KoolStop. Ask for them by name!
  5. KCvale
    KCvale Active Member
    Feb 28, 2010
    3,898
    23
    Errgghh, sound like you bought a thinner Presta valve stem tube and not the common fatter Schrader valve stem tube.
    Presta's are meant for very thin racing rims (too thin for a Schrader) and a real pain in the butt, I can't stand the blasted things.
    If your rim in the center is over 1" you will likely have a Schrader size stem hole.
    What I do to 'bullet proof' a wheel is use a HD tube which is about 4x thicker than a regular tube, and then put a HD liner between the tube and inside of the tire, and of course make sure you have your inner liner where the spokes come into the wheel.
    ~$25 a wheel but worth it for many.
  6. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    I use double walled rims Rhino Lite. For a time I kept getting flats. The hole was always on the part of the tube nest to the spokes. The rims have brass sleeves for the spoke nipples to go through. Where the sleeves had been put in I notices little shards of metal around them. Sanded them down and now I don't get flats like I was before.
  7. a.graham52
    Nov 22, 2013
    232
    well so far so good. agree KC my rim was ment for a proper schrader valve, but the presta is working so far, and i bought an adapter so i can use a schrader vavle tire pump. put some new tires on last weekend so that wil lhelp out too!
  8. KCvale
    Feb 28, 2010
    3,898
    23
    Cool, that's all that matters.
    Your adapter will work with a manual tire pump but not with most compressor tire fittings unless the fitting has a manual air release.
    All the ones for my compressor require a Schrader valve to push in the air release in the fitting to let the air flow which really irritates us in the shop hehe ;-}
  9. a.graham52
    Nov 22, 2013
    232
    i fell ya. before i bought the adapter, i knew if i had a flat tire at work, id be done. haha.
  10. Citi-sporter
    Citi-sporter Member
    Jun 16, 2014
    120
    When you patched your tube, did you lightly inflate it to shape before inserting it in the tire? Also, when putting the tire back on the rim, with your properly inserted and lightly inflated tube, check with your eye(s) that part of the tube isn't between the bead and rim, push on the valve stem to unseat it from being trapped by the tire's bead. then pump in a couple of pounds pressure, just enough to fill the tire out and check that the tire's seating 'line' is concentric with the edge of the rim.
    99% of all Ka-BLAM! flats after tube replace/repair can be traced to improper tube installation.
    #10 Citi-sporter, Aug 28, 2014
  11. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    I have had two blow outs since 2009, one was while I was cruising at around 35 MPH, it took all I had to keep that bike upright when she blew....LOL I was all over the side of the road for a little ways and finally got it into the grass and dirt when I got-ur shut down, yep it was a heck of a ride, fortunate I wasn't in a corner when it let go, that would have got ugly real fast..ouch!
    Second blow out was with bike parked just outside my shop, had just made my fastest all time MPH run on the old 1963 Western Flyer 20-30 min. earlier, which was a GPS'd 50.3 MPH, if that tube would have blown while on that ride, thre is no doubt I would have gotten hurt bad.
    This last experience was when I decided the high speed runs on my bikes are over, 50+mph is just to fast and it just ain't worth the risk, I'm just cruising from now on in the 30's - low 40's and I am using better tires and tubes also, no more 50MPH for me on a bicycle.
    Map
