Bicycle motor with a cat?
As to the pollution problem...ever think about how much pollution a single trip cross country in a 727 makes?
How about the fact that most trains leak more oil in an hour than a two stroke bicycle motor will use in it's entire service life.
Or all those idling police cars?
Ever follow a garbage truck? City bus? Big Dodge Ram diesel?
Or what about all that smoke that comes out of the top of a Bogus King restaurant?
When did the EPA do it's comparison? 10-15-20 years ago? 2-stroke oil has improved alot in the past few years.
Two strock oil has definitly improved, I had some cheap oil from a Autozone store in bind. The china did smoke more. As for the cat existing, theres just no way it would cost more for a kit. The rare metal thats in them. No way, good observation! I've got got some blinker bearings for turn signals I'll sell, anyone?
They are starting to make a CAT muffler for our little 2 strokes it is not BS, now weather the BGF pipe actually has a CAT I don't know but I know dax is starting to market them. This is what it looks like inside.
Now that looks like a cat to me...thats exactly what you would see in a automotive cat...almost like a honey comb (^)
I wonder how they can keep the cost down. Platinum is a precious metal and putting it in a china fire engine and still keeping the cost down sounds like a Oxy-Moron. If it will keep the engine around longer, I'm all for it. I wonder if it requires the modification of the fuel mix to a higher fuel ratio. It would be difficult to lean out the oil ratio with the loose tolerance and poor quality of the bearings used. I would like to see and smell less of the two smoke. Have fun, Dave
Since these engines have been shown to easily pass EPA regs in Arizona, I think they are putting a piece of corrogated metal in the exhaust and calling it a cat.....
Correct me with real numbers and stats if you will, but I don't think the 24:1 exhaust from an ancient tech piston ported two stroke will light off any kind of cat.
Also, doesn't oil kill cats?
Don't cats need computers?
Is this some new tech that was taken from alien spacecraft?
Bike Guy Joe : Do you get kind of a higher pitched noise from you CAT muffler? We had installed one of BGF CAT66 motors on a shwinn. We had to extend the pipe to about 15 inch. Would this change the pitch of sound the muffler makes?
Correct me with real numbers and stats if you will, but I don't think the 24:1 exhaust from an ancient tech piston ported two stroke will light off any kind of cat. I THINK IT IS 700 DEG. SO IT WOULD NEED TO BE CLOSE TO PORT.
Also, doesn't oil kill cats? YES but 50 TO 1 RATIO WORKS
Don't cats need computers? NO
Is this some new tech that was taken from alien spacecraft? YES
Have fun, Dave
From what I read the muffler is called a cat muffler but doesn't have a catylitic converter. all it does is burns up the unburnt fuel and oil in the muffler. Thats what I heard anyway.
BSA
Here is a sure fire way to fix the emmissions problem. Some of my fellow R/C airplane associates use the Cohlman fuel mixed with castor oil in their tanks. They use this mix in their weed eaters too.
The end results are no smoke and a very clean burn to boot.
So I reccommend the white lightning fuel and castor oil mixture as your cure. Good luck at the state testing shops for you all in CA.
Maximo
The Inside Is A Lil Diffrent That Screw Serves No Purpose Its Welded On To The Can. There Is A Honeycomb Inside It Tho. The Honeycomb Has A Big Washer On The Side That U Can C From The Cap Side. It Rattles Like **** Tho
