Hi,
First time on this thread. I have found it very useful and encouraging. I am restoring a 1974 Velosolex, using the Hongdu engine. I live in Canada so it is easy to get the engine. Everthing is working fine, but I couldn't believe the original design of the muffler joint. I cut out a chunk of the exhaust pipe and use a length of silicone heater hose. That burned out pretty fast, probably because I removed so much of the exhaust pipe and exposed the hose to the direct exhaust. So I cut out even more of the pipe, attached the exhaust pipe to the front wheel axle and used a flexible stainless steel pipe to replace the section I cut out. Because the flexible section is quite long, it flexes nicely.
