mapbike
I installed a NGk bpr7hs and it made a huge difference. I rode a good 10 miles again without a problem. I just pulled the plug back out and it's black again and wet what should I do the mix ratio at? Also I'm not very fond of this carb, seems to idle sometimes and others it won't. What would you guys recommend for a aftermarket carb with more control?
Buy some Opti2 2 stroke oil mix 1.8 oz per gallon for a couple hundred miles and then mix about 1.3oz per gallon from there on out.
Thats what I do and all my engines run great.......
On the carb, go to thats dax web site and order an RT Carb and a cable from Duane and put the #70 jet in it to start with and see what you get, these are good little carbs and I have beenrunning one on one of my bikes for a year now with great results.
Map
