Richluhring
so my engine is bogging at any throttle position once it levels out. whether it is 1/4 to wot. I have replaced the plug and fuel it came on sudden. I have checked intake and exhaust port, tightened all bolts, cleaned the carb, exhaust pipe is clear. I run 32-1 fuel/oil, now when it starts if I let off the throttle and then twist it back up. it clears up. the plug is a perfect light brown. I have opened up the air cleaner by adding some hole. that helped a little. it has well over 600 miles on it. I have the fuel needle set to the top slot. that is where it runs best. I have checked the magneto,. it idles perfect and has power. it runs great until it reaches its top speed for the throttle position then it bogs/or four strokes. am not sure which it is. it does seem to not bog if I am going up a slight incline, but going on flat ground or slightly down hill to a lot down hill it Boggs a lot. HELP!!
I HAVE TRIED ALL THAT I CAN..I AM LOST
