16v4nrbrgr
After taking a look at how the clutch and CVT have been working, I might not go ahead and mod anything yet.
The steel 3 shoe clutch hasn't broken into the drum yet, so any mods will change once it does. I also don't look forward to taking the shoes out to drill them in a press, so if I need to do it, once would be nice. I think from what I have read about the three shoe steel clutch, its more worthwhile to get the aluminum one rather than drill it full of holes. The weight of the steel shoes is actually an advantage under overgearing or overloading, the aluminum may generate too much heat and burn out quickly.
The CVT looks as if it might need to engage early just to keep from spinning away power, at least with a stock belt. It isn't under any tension without centrifugal force, which is good news for the rest of the drivetrain, it definitely must slip some off idle.
The transfer case in the CVT leaks gear oil, and I'm monitoring it on the counter, if it just oozes I'll use red moly CV grease. The first oil change showed it didn't puke everything, but there was also break-in crap, maybe oil for one more shakedown before grease.
I think once the clutch breaks in (it fortunately shows no signs of overheating) with the 41t, it will be much better.
Keeping everything I stock that I can is the plan, when you need to replace parts its nice when they are cheap AND convenient.
