cannonball2
Electronic theory is not a real strong point with me. Wiring and so forth is something I am pretty good at. I have a charge coil from a B&S electric start lawnmower. It is designed to use the flywheel magnet. It charged the battery. I bet the Ryobi si similar in operation to the Briggs, probably doesnt have a regulator, but is limited to a constant output that wont harm the battery. The Briggs coil is very small and could probably be mounted to the Ryobi, just need a simple bracket, mounts like the ignition. The guys flying industrial R/C helicopters use a brushless motor driven by the engine, or one of the driven shafts in the heli. They do have some form of regulation. You could build something similar to be run off the flywheel(friction drive of course)
