Nice fit!! Can I ask why you think the torque converter might not work? Bike is looking good...![]()
Depending on your pulley size going to rear wheel it could slip. With an Ax belt and the pulley no smaller than 2.5 it won't slip. If you run just a v belt oh ya it's going to slip. Also a spring loaded tensioner will help a lot to prevent slipping. A clutch is a way to go but that's more for racing. The cvt is the best drive for the streets.
Wes I agree, What s a Ax belt? ......... Curt
This is going to be a slow build and I'm hoping to get it done for the summer and my funding is coming from donating plasma which is $200 a month
Get rid of that jackshaft! Find a shaft for your cvt that puts the sprocket inboard and not outboard which is why you think you need a jackshaft. I've seen em but never looked into it. And with 24" tires you'll definitely be fine with a tall ratio like 6:1, that is the same as my current high gear ratio of 6.4:1 on 26" tires. I don't have the billet parts so I geared it like that to not overrev in either gear. Might want to run 35 chain to get the big rear sprocket for that, or 10 to 60 if you can find a 60t #41. Believe me! It is one less point of power loss especially when you consider the chain alignment tweaking out under power...
