Thanks! She's a bit of a squeeze to get in there! I did have to mill some material off of the front mount to get it to work because of the bolts holding the engine to the plate. The cnc motor mount they make for this engine would have been much smarter and easier to work with.Nice fit!! Can I ask why you think the torque converter might not work? Bike is looking good...
Wes I agree, What s a Ax belt? ......... CurtDepending on your pulley size going to rear wheel it could slip. With an Ax belt and the pulley no smaller than 2.5 it won't slip. If you run just a v belt oh ya it's going to slip. Also a spring loaded tensioner will help a lot to prevent slipping. A clutch is a way to go but that's more for racing. The cvt is the best drive for the streets.
Notches molded into underside for the flexibility to fit smaller diameter sheaves...a v belt with notchesWes I agree, What s a Ax belt? ......... Curt
Excellent!!!This is going to be a slow build and I'm hoping to get it done for the summer and my funding is coming from donating plasma which is $200 a month
Half the point of my jackshaft is because I'm going to install a disk brake on it. I do get what you're saying though. And I'm only using this transmission because I already had it from another build that it was too big for. My main plan is a centrifugal. But I want to see how this runs since I already paid for it. And I'm not using the 41 chain it's too big and will move around too much. Im going to use 35 or 415 that I have chain and sprockets for. Might have to reorder some parts though. Not sure yetGet rid of that jackshaft! Find a shaft for your cvt that puts the sprocket inboard and not outboard which is why you think you need a jackshaft. I've seen em but never looked into it. And with 24" tires you'll definitely be fine with a tall ratio like 6:1, that is the same as my current high gear ratio of 6.4:1 on 26" tires. I don't have the billet parts so I geared it like that to not overrev in either gear. Might want to run 35 chain to get the big rear sprocket for that, or 10 to 60 if you can find a 60t #41. Believe me! It is one less point of power loss especially when you consider the chain alignment tweaking out under power...
