johnloganb
im am trying to remove the outer bearing on 66cc engine can anyone help me thanks
Aluminum is a very soft medal and is too easy to warp!The bearings are a lot easier to remove and install if you heat the case with a propane torch.
Where is a good place to buy the clutch shaft bearings?
prolly because your bucking bar and that one single little ball bearing is dry and needs greased? it is always the simple stuff first.These H.T. engines can come up with some interesting squeaking noises when those to parts are dry and screeching.Bother for Common knowledge maybee?
i have a bearing squeaking and seems hard to pedal- I think it's the outer, and they don't seem to be at many of the vendor's sites.
