Front 20.5lb without brake plate, rear wheel 43lb, with 19” tires. Hub motor alone is 29lb. 65lb in the wheels alone, yikes!
So the treats rims spoke holes are drilled 5.5mm. My guess is these are made for 11g spokes. The 10g nipples measure 5.75mm. I drilled them to 6mm and broke the edge with a c-sink.
Laced them up. My fingers hurt BAD from the 4 inch long, eighth inch thick spokes on the rear wheel. The last 8 spokes took me half an hour. Truing another night. Got a long way to go.
