Number 5
Well OB "Bill" the tank graphics are fineskind and the completed machine is a Masterpiece. You got to get out as the weather warms and show off.
The Harley people will be blown away with the spirit of the by gone tribute.
One thing in the completed machine and then looking in early photos, I noticed your bike has an internal throttle cable actuator ala Harley.
Would you like to inform us as to that throttle came about, and how it was installed in the handle bar end?
That throttle assemble is a aftermarket direct copy of a unit from a Honda Trail 90.
I had to machine a slot in the bar to install it. I used the same setup on my last build, they work great.
You can go stealth from above with that shade on the headlamp. I always liked the lens diffraction type you have. I had that on the bike DC generator that rubbed the side wall of a tire, for front white and rear red incandescent bulbs.
Sweet Ride!
Make a chaff sprinkler and your all set.
Is there anything inside if somewhat hollow, what is supporting the engine below it?
The bike is marvelous!
The piece under the engine is hollow, basically needed a motor mount and decided to build it this way to give the engine more “body” .
Now what is a “chaff sprinkler” ?
Just what I thought. Some years back, I did lots of looking and the Trail 90 throttle guts are the only internal that fit a standard bicycle handle bar internally. Seems if I recall the push-pull button slot was machined as a helix. Whereas the best I could do is mill a angled slot.
Did you save any photos and metric details of the throttle slot?
I have a bag of the Trail 90 throttle parts and would like to use them to replace the clunky Flyer twist grip.
No helix slot involved Tom, just a straight slot with a round hole at the end. I’ll see if I can get some pics and dimensions from a new handle bar today.
I was wrong, the throttle assembly was a aftermarket direct replacement kit for a Honda Trail 70.
I took some measurements off of a new Honda handle bar, I machined this slot in my bar and used the kit and it worked great.
Don’t mind my hand written notes, it’s the specs that count.
I knew about the headlamp shield from Grand Parents that did drive with those on their automobile during WW2, but it was before my time.
Chaff, the stuff that aircraft expel to throw off a moving target, the little metal fragments or maybe it is like tinsel.
I wonder if the post about the mini fold up motorcycle that the Brits would shove out aircraft in post I made elsewhere on MB. Forgot where?
This all to have faster than hiking near enemy lines.
No lights on that thing.
Paratrooper picks up mini motorcycle that also parachuted out aircraft and push starts.
Video from way back when
I just realized I never added the latest pics of my build. I found the rear rack on the CABE and installed it. I think it made it look a little more period correct. I took it to a motorcycle show and competed against a whole lot full of custom Harley’s and Jap bikes and I got a first place for “Oldest Bike” . I entered it as a 24 Billesbach,(never said it was a 1924 or a 2024, I let the judges make up their own minds). I also took it to a couple of car/bike shows and got first place at both for custom bike!
View attachment 114479View attachment 114480Got the wheels all laced up and tires mounted, so now it’s time again to put it half way together again and start working on the pedals and belt drive. Gots lot to do, but what’s the hurry ? The fun is in the build
Might I ask from where you acquired the tank? I’ve been trying to locate one of those for years. Or did you fabricate it yourself?
