Number 5
Well truth be told, my original intent was to build a three wheeled recumbent, to be pedal powered. But common sense took over and told me exercise is overblown ! I keep telling myself that the more one exercises, the more wear one puts on one’s body ! Kind of like a car, it’s only good for so many miles, but more miles if you don’t abuse it !!
Then I remembered I had this engine in my bone pile and pedal powered be dammed, gas bike here we come again!
LOL, I have a Sun cruiser my son got at a garage sale for $10 about 10 years ago. I get on it everyday and sometimes when I get overwhelmed or frustrated, I jump on it and take a quick ride, It's good for the legs and back, I don't go far just enough to limber up and break the cycle...........Curt
I am thinking the PO dumped it and decided to not get heart again.
I ride everyday and the Electra cruiser hauls my groceries sometimes with 4 gallons of water on the bars... gets me to my appointments and a few pallets when I see them... The best is when I fill my gas jug for the lawnmower... I need 2gal. On the pump with the bike... ;)
Nice work OB!
This forum is kinda wonky, I have you followed and your new posts don't often show up in my Email. Using a 24" rim as a drive sheave is a detail that is missed by even advanced builders.
Thinking of those using Whizzer sheaves.
Using the copper rivets clinched to roves deserves a bit of how to this thread for all posterior.
You are way ahead of the average for using fastening methods like that.
The problem with my V-belt slipping in the past may not exactly correlate to your type of belt that you use. I do note that you made your own sheave and it from a bike rim that is far from a V-Belt sheave.
My replacing my washing machine V-belt from cast aluminum type to a clone of the Whizzer V-Belt sheave of stainless steel was initially a good idea. Though it did slip quite a bit till after a year I noticed why it slipped. A bump where the manufacturer butt welded the formed extruded metal was raising the belt up as it passed by the weld that was not smoothed out enough. It was like it would slip only when that bump was touching the belt as it rotated.
A little use of my die grinder and a Dremel tool and no more problem.
Just though I would mention this as all those little bumps of those rivets may or may not be a similar situation.
Just the idea that as much as you can build from scratch and not buy already made part is Commendable!
Sure to be watching this thread.
MT
I also decided to incorporate a exhaust cut out, so I took a 3/4 pipe t and fitted a flapper in it to direct the exhaust either through the muffler or with a flip of the lever, straight down. My plan is to use a pair of old Schwinn Varsity break levers on the bike. Right one will operate the front Sturmey Archer drum brake and the left will operate the exhaust cut out.
I also decided to incorporate a exhaust cut out, so I took a 3/4 pipe t and fitted a flapper in it to direct the exhaust either through the muffler or with a flip of the lever, straight down. My plan is to use a pair of old Schwinn Varsity break levers on the bike. Right one will operate the front Sturmey Archer drum brake and the left will operate the exhaust cut out.View attachment 114568View attachment 114569View attachment 114570View attachment 114571
Nothing like a set of classic Weinmann hand levers, they are kid proof. :D
Well I spent a few evenings working on bits and pieces. I got the other rear fender bracket made and installed and I was able to mount my faux oil pump which is now my crank case breather, and run the copper tubing for it as well. While I was tinkering I went ahead and welded a tail pipe to the muffler. I think it looks better than just a plain hole in the end.
