Number 5
Oldbiscuit
375
1,192
93
68
Well truth be told, my original intent was to build a three wheeled recumbent, to be pedal powered. But common sense took over and told me exercise is overblown ! I keep telling myself that the more one exercises, the more wear one puts on one’s body ! Kind of like a car, it’s only good for so many miles, but more miles if you don’t abuse it !!
Then I remembered I had this engine in my bone pile and pedal powered be dammed, gas bike here we come again!
curtisfox
6,081
4,056
minesota
LOL, I have a Sun cruiser my son got at a garage sale for $10 about 10 years ago. I get on it everyday and sometimes when I get overwhelmed or frustrated, I jump on it and take a quick ride, It's good for the legs and back, I don't go far just enough to limber up and break the cycle...........Curt
I am thinking the PO dumped it and decided to not get heart again.
Mossy
1,128
819
I ride everyday and the Electra cruiser hauls my groceries sometimes with 4 gallons of water on the bars... gets me to my appointments and a few pallets when I see them... The best is when I fill my gas jug for the lawnmower... I need 2gal. On the pump with the bike... ;)
  • Like
Reactions: Wevil Kenevil
Tom from Rubicon
2,845
6,138
Rubicon, Wisconsin
Nice work OB!
This forum is kinda wonky, I have you followed and your new posts don't often show up in my Email. Using a 24" rim as a drive sheave is a detail that is missed by even advanced builders.
Thinking of those using Whizzer sheaves.
Using the copper rivets clinched to roves deserves a bit of how to this thread for all posterior.
You are way ahead of the average for using fastening methods like that.
Oldbiscuit
375
1,192
93
68
Thanks Tom. I did the same on Le Miserable, using a 24” rim and riveted leather belt. People told me it was unnecessary, but I didn’t want to leave a bunch of empty spoke holes, plus I was a little worried about belt slippage.
curtisfox
6,081
4,056
minesota
So KOOL! 90percent of the slippage was on the small driven pulley, (or was on my old Monark twin). The belt didn't rap around it enough, could be resolved by a idler fixed to make it rap around more. But when you are only 15 all you want to do is ride, and not think about it LOL just tighten it up and go..............Curt
MEASURE TWICE
2,775
1,274
CA
The problem with my V-belt slipping in the past may not exactly correlate to your type of belt that you use. I do note that you made your own sheave and it from a bike rim that is far from a V-Belt sheave.
My replacing my washing machine V-belt from cast aluminum type to a clone of the Whizzer V-Belt sheave of stainless steel was initially a good idea. Though it did slip quite a bit till after a year I noticed why it slipped. A bump where the manufacturer butt welded the formed extruded metal was raising the belt up as it passed by the weld that was not smoothed out enough. It was like it would slip only when that bump was touching the belt as it rotated.
A little use of my die grinder and a Dremel tool and no more problem.
Just though I would mention this as all those little bumps of those rivets may or may not be a similar situation.
Just the idea that as much as you can build from scratch and not buy already made part is Commendable!
Sure to be watching this thread.
MT
Oldbiscuit
375
1,192
93
68
I’ve been playing out in the shop and still tinkering on number 5. I got the exhaust fabricated and installed. I had a chrome muffler off of one of my China girl 2 cycle engines that I decided to use, but I removed one inner pipe and opened up the outlet.
Oldbiscuit
375
1,192
93
68
I also decided to incorporate a exhaust cut out, so I took a 3/4 pipe t and fitted a flapper in it to direct the exhaust either through the muffler or with a flip of the lever, straight down. My plan is to use a pair of old Schwinn Varsity break levers on the bike. Right one will operate the front Sturmey Archer drum brake and the left will operate the exhaust cut out.
Oldbiscuit
375
1,192
93
68
I wanted to build this with full fenders front and back and am still contemplating a rear period correct rack. With the rear wheel having to go straight back to remove, I decided to make the rear fender in two pieces. I still have to make the back fender stays, but I need to source some more scrap metal.
Tom from Rubicon
2,845
6,138
Rubicon, Wisconsin
I also decided to incorporate a exhaust cut out, so I took a 3/4 pipe t and fitted a flapper in it to direct the exhaust either through the muffler or with a flip of the lever, straight down. My plan is to use a pair of old Schwinn Varsity break levers on the bike. Right one will operate the front Sturmey Archer drum brake and the left will operate the exhaust cut out. View attachment 114568 View attachment 114569 View attachment 114570 View attachment 114571
Nothing like a set of classic Weinmann hand levers, they are kid proof. :D
Oldbiscuit
375
1,192
93
68
Well my plan is to take this modified fire extinguisher that I added a pump plunger to and mount it on the front down tube. I will run a copper line from the breather port on the valve cover to the bottom of the extinguisher to mimic a oil pump FDD or the engine but in reality it will act as a breather/oil trap for the crankcase.
Oldbiscuit
375
1,192
93
68
Well I spent a few evenings working on bits and pieces. I got the other rear fender bracket made and installed and I was able to mount my faux oil pump which is now my crank case breather, and run the copper tubing for it as well. While I was tinkering I went ahead and welded a tail pipe to the muffler. I think it looks better than just a plain hole in the end.
