I'm taking some satisfaction that my dimensions used for machining the reduction drive and relocating the e motor were perfect and resulted in the motor case being located in exactly the same frame position as before. I anticipared the case itself might have to be adjusted a little, but no back to it's original location it went.
Pedal chain comes tomorrow. I've a lot of room for wheel adjustment, but as 118 links of 420 is heavy I may fab a combination spring tensioner/brake arm anchor for return chain support and control and mounting it just in front of the rear sprocket. This one would be welded to the chain stay to prevent a twist of the tensioner into the spokes. Those of you who've been around for more than 20 minutes know what I'm talking about.
I am starting to visualize a case cover and small chain guard for the drive side. Knowing now I'm set on the position of moving parts I can plan
for drive train safety and cosmetic treatments for the motor case housing.
Other items I really don't like are my key switch and my throttle and brake levers. So those will be repaced. I prefer split ring motor cycle style brake levers so I don't have to remove grips or throttle to remove a brake lever. Simple push switch on the bars for on or off. I have 3 e bikes which have key switch on the rear racks and dislike them all.
Rick C.
