So I did some riding today, I have now put 9 km on the bike, it’s running fine but it got some small issues. First of all the chain bounces up and down when I ride, (I don’t know if it’s normal but it is shaking a lot up and down with a distance of maybe 2 cm), however when I go fast (30 km/h) it runs in a nice line. I don’t know if it it’s either normal or a problem, but it seems odd.
Secondly, the oil leak haven’t stopped. It’s a lot better now that I have reduced the oil percentage, but it’s still spitting out oil around the cylinder exit (this might be because the gasket ripped and I’m using a old thin metal one).
Third of all, the tank haven’t completely stopped leaking. I put some paper around it last night and today it was pink, indicating the leakage. It’s only leaking from around the exit part of the tank, but I drips and hits the wires and runs down to the carb. This is annoying as I’m loosing fuel, and it’s making the bike dirty and wet.
The last problem is very weird. I have now experienced it three times, and don’t know what’s causing it. Sometimes when I ride it simply just goes full throttle and I can’t stop it. Even if I pull the throttle back and fourth it’s just sitting there at max rpm. I then have to shut it off with the killswitch. When I start riding again it’s fine. This is very weird and can be problematic as it gets loud if it’s just idling and can just take off all of a sudden.
I hope you can help me out with any of these problems.
