Nice build, twisted sister belt and all. I'd think that a spritely speed for scaring livestock and raising dust. Well done!
Rick C.
Rick C.
That is just so awesomeHere’s you a washing machine motorbike. With the long spring seat and the beehive springer it rides like a Lexus. However even with the much modded Maytag it’s only good for around 20-25. A real taste of early motorcycling. View attachment 103171
Forks are a matter of degree and what you're used to. No reason to expect a $150. fork to preform like a $1,000. downhill setup. If your used to no suspension a sprung fork of any type feels pretty good. I build vintage style bikes with1900 era forks girder, dual spring, single spring, leaf etc. with no rebound control so I don't expect much in the way of suspension & and there isn't, compared to a decent MB fork with hydraulic or air rebound control and a world of difference from the really good stuff with 5" of travel or more.
It's hard to prove something in a court of law let alone in print so enjoy what you've got and upgrade if you want proof, but it really costs to do so. I like round steak and love ribeye and because I've tried both I have proof of which I prefer, but I still eat and enjoy round steak more often because it's quite affordable and tastes good, just not as good.
A bucking fork by definition, is one that doesn't have adequate rebound control or no rebound control. The spring compresses to absorb the initial shock, but slams back to it's stationary position too quickly without adequate resistance from some type of shock absorber most frequently hydraulic or air types on better forks. Thus a fork alternately compresses and slams resulting in that "bucking" feel. I know this feel well because all my classic fork equipped bikes demonstrate some degree of this characteristic and that's what I use on all my bikes builds, but on my mountain e-bike I have really good full suspension forks and shocks that ride like a dream compared to any of my classic forks on hardtail frames.
Rick C.
Rick C.
HhiForks are a matter of degree and what you're used to. No reason to expect a $150. fork to preform like a $1,000. downhill setup. If your used to no suspension a sprung fork of any type feels pretty good. I build vintage style bikes with1900 era forks girder, dual spring, single spring, leaf etc. with no rebound control so I don't expect much in the way of suspension & and there isn't, compared to a decent MB fork with hydraulic or air rebound control and a world of difference from the really good stuff with 5" of travel or more.
Rick C.
Your suspension is very interesting there's alot going on in this picture. I think I'm seeing a barba racing motor? The silencer would be nice for me to continue using this thrust pipe, looks stock which I definitely have as well as a welder. Looks like a moped drum hub? There's alot going on there that is a beautiful, intricate bikeYep quality on forks, hubs/wheel & tires. Brakes 200 mm front and rear. Check Ghetto bikes out for quality sealed bearing hubs front and rear or complete billet wheels sets with 12 or 10 ga. spokes. 110mm or 135mm spacing. Rear hub is set up for disk on right side and motor drive sprocket on the opposite. Setup this way lessens brake contamination from two stroke oil, for bikes with left side exhaust. I run the his rear hub/brake on my 2 stroke hybrid e-bike & would run his front hub were it not for the e-motor up there. I run 180mm up front and back as well, but bigger rotors are better...if you've room for them. I'll be going up on rotor size soon.
My hybrid is a Grubee with 5" extension plates gives 53" wheelbase and makes the bike much more stable at higher speeds as would adding a frame to fork stabilizer, which I've run on other bikes that displayed bad manners at high speed, the so called "death wobble", but the Grubee with longer wheelbase doesn't require one. Whatever fork you run no matter the price or quality make sure it has positive trail measurements. My Grubee shows 1.5" positive. My fork is an antique style single spring toggle type certainly not comparable with a good downhill fork and still it tracks well at speed on roadways and not at all an off road setup!.
Rick C.
Thanks Noah. I'll post a front end photo which will help. This bike is an electric hybrid and also think the hub e-motor looks like a drum brake, but actually it's disk brakes front and rear. The rear hub is billet aluminum with sealed bearings from Ghetto bikes.Your suspension is very interesting there's alot going on in this picture. I think I'm seeing a barba racing motor? The silencer would be nice for me to continue using this thrust pipe, looks stock which I definitely have as well as a welder. Looks like a moped drum hub? There's alot going on there that is a beautiful, intricate bike
Everything about that bike is beautiful I'm guessing this is your pride and joy, the project you really put your all in. The hybrid thing is very enticing, not having to pedal that first ten feet to pop start it now that would be great, same reason I've been thinking about a centrifugal clutch. I definitely have expierenced the sudden YIIIIIIING and slow to a stop, walk back and look for the chain haha I've been running a 410 from tractor supply for a while now and it's extremely reliable much better than the kit 415 and very cheap i got a little more than two chains for twenty bucks, I forget the exact length but I know I have a spare. I'd love to see some more pictures of your bike especially your ' case saver' I haven't heard of this and I'm interestedThanks Noah. I'll post a front end photo which will help. This bike is an electric hybrid and also think the hub e-motor looks like a drum brake, but actually it's disk brakes front and rear. The rear hub is billet aluminum with sealed bearings from Ghetto bikes.
The x-chamber is a thrust pipe, stinger shortened with a kit muffler attached. Really quiet. The motors I personally build, many mods a few of which are reed valve, window piston, extra cylinder port, German precision bearings, balanced rotating components and a welded stuffed case, porting and slightly higher compression etc. All the external stuff is just stock as ordered, heads, Dellorto, RSE reed and as much extra finned aluminum as I could bolt on for extra cooling & it looks ok too. Two things bolted to the case is a spring chain tensioner and behind that an aluminum case saver which could be called a life saver as well. It's purpose is to prevent chain to case lockup should the chain break. These are common factory motorcycle incorporated devices for bikes that run tight chain to case tolerance at the output sprocket and the China girl engines are the tightest chain to case that I've ever seen and therefore dangerous. Rear wheel lockup is not as dangerous as front wheel but it's not good. These really work I lost a fast link twice (installed clip backwards) & both times the chain spit through and cleared without my noticing the chain was gone, engine rev'd and progress slowed the chain was a few hundred feet back up the road.
Photo is old before I changed the battery mount and painted the aluminum wheel. The lithium battery is under the down tube and saddle bags hold two more...I have room for 5 total on long rides they are 20 amp hrs. each. good for lots of miles. The modified motor is a fuel hog, but with the 38 tooth sprocket at 35mph cruise I can squeeze 100mph per gallon with a little help from either pedaling or 500 watt, wink,wink, e-motor.
Rick C.
Thanks!That is just so awesome
Thanks Rick!I'd say yours is very cool!
Rick C.
