4 stroke with sickbikeparts jackshaft
waynesdata
254
109
43
46
I like Schwalbe allot. I compromised comfort for performance. I have never had tires that grip pavement like the 60a Maxxis Hookworm. They seem to stop and corner better.
xXNightRiderXx
515
229
43
Boise
Hookworms are a pretty soft tire too. Personally, I'd rather have comfort. I plan on taking long trips with this bike, so I need as much comfort as I can get, without sacrificing a whole lotta performance. 50mph gets me on the rural highways and back roads, which I can use to get from state to state.
indian22
4,725
7,709
Oklahoma
Is 3 D still in business? Several posts awhile back indicated their not. I like the clutch & hope they are still around for us guys that like pedal bump starts over pull.
I just went 203mm rear on my hybrid and still running 160 mm rotor front, but am leaning to 180mm, mechanical Avid for the front. My Simplex has 160mm front and rear 80mph bike with 12.5 hp and 5 speed wet clutch transmission/kick start. weighs 175 lbs. It stops but I'll eventually go dual rotor 203mm on front and single203mm on rear...both hydraulic when I add the sidecar, which will also have a disc brake.
My hybrid makes 5 + hp with a reed modified, third transfer port and window piston China girl (and a lot of other mods) to make it go plus the ehub equal a 40 mph cruiser, without high rpms. It really needed decent braking and that's still a work in progress. I'm running 38 tooth and 2.2" Maxxi Holyrollers at 65 lb. pressure.
Rick C.
  • Like
Reactions: waynesdata
indian22
4,725
7,709
Oklahoma
indian22
4,725
7,709
Oklahoma
They actually look wider when mounted and of course they actually sit wider when mounted on wide wheels 2.125" compared to skinny rims...this has caused some builders problems with chain clearance, especially with China girl engines on kit builds, especially rag joint builds but also some hub adapter sprocket mounts too. I'd think this not an issue with your current project, just a heads up.
The Fat Frank mount well and run higher pressure too. I think you will be pleased with your choice.
Rick C.
xXNightRiderXx
515
229
43
Boise
Rick C.
Luckily, my fender fits a 2.35 tire, so I'll get a lot of metal noise if I have clearance issues. I'm thinking 45-50psi will suit nicely for a combination of grip and efficiency.
  • Like
Reactions: indian22
xXNightRiderXx
515
229
43
Boise
https://3dmotorsport.net/products/3dma-racing-clutch-3-4
Shows they still up and on the site? I remember that post and looked right away, a piers the same. Don't know why that guy posted, i like what msrfan did with his, he advised them on some improvements. He is in CA. and they ride a lot and its worked out well.........Curt
I'm gonna use that for my stingray build. I'm planning on using a 198cc direct drive with a peerless 5 speed transmission, so that clutch will come in handy. Most especially with the e-start. Thanks curtis.
  • Like
Reactions: indian22
waynesdata
254
109
43
46
If I may
This is my R&D build, and my first four stroke. Don't do mag wheels, they're too heavy. Go 8 speed for the gear range, and do the x.8 (sorry, it's the X.4) system from SRAM with a 40t-11t range cassette. You'll get crazy acceleration off the line. I also had to swap my mechanical AVID BB7s with mechanical hydro BB7s to compensate for the heavier wheels.
Be aware that your drive side chains may bind once you start shifting up. Take actions to ensure this does not happen, such as increasing the gap between sprockets or adding in a slip disc (a metal disc made to prevent chain binding)
I am not sure how your gearing works. Do you have more than one front chain ring? I am keeping the mags because they seem to be more stable going down very steep hills 40 to 45mph.
Just a theory: I think the weight of heaver bikes dampens most types of vibration including high speed and engine vibration. I could be wrong just my observation
  • Like
Reactions: indian22
curtisfox
6,048
3,959
minesota
These only come 3/4" so if you have 5/8" shaft you need a bushing, you can get them with key-way cut in them, and a 3/16" x 1/4" key......Curt
  • Like
Reactions: indian22
waynesdata
254
109
43
46
I do not understand. Are you taking about the output shaft adapter for doing a TAV2 or similar install? Sorry I am still learning.
  • Like
Reactions: indian22
xXNightRiderXx
515
229
43
Boise
Yes, I am using both chainrings provided in the SBP shift kit bolted onto the freewheel they also provide. I recommend swapping out the bolts they provide for some better grade 8 bolts from home depot.
Mag wheels will allow the tires to absorb road vibrations better, but that is the extent of their advantage. They are significantly heavier than spoked wheels, and thus require stronger brakes and more engine torque to turn at the same speed. Spoked wheels will accelerate faster and roll faster for the same amount of torque. You do have it right though, they are more stable at high speeds due to the increased rotational mass and inertia.
  • Like
Reactions: indian22
waynesdata
254
109
43
46
Rick C.
If a "160mm front and rear 80mph bike with 12.5 hp" can stop 203mm would be overkill for me. Good chance a bike with that kind of power is also heavier.
  • Like
Reactions: indian22
xXNightRiderXx
515
229
43
Boise
All the more reason to have a 203 on the front at least. You want to be able to do emergency stops. Im doing a 203mm with Shimano SLX hydro on the front and a 180mm with a mechanical hydro on the rear when I build the stingray.
indian22
4,725
7,709
Oklahoma
Thanks Curt I bought a 3-D but let a friend use it on a go cart (20+hp) and it's worked great. I bought it in anticipation of building a bump start 212 Predator but didn't happen yet.
Rick C.
indian22
4,725
7,709
Oklahoma
Yes it's about 190 lbs and has a 53" wheelbase and yes your correct weight tends to smooth things out on well designed bikes & fabricated rides, but excess un-sprung weight is never a good thing in and of itself. Weight with purpose such as improved strength and/or rigidity, as examples, is ok as long as it's located as low as possible and doesn't significantly alter the correct weight balance front to rear with rider mounted.
Brakes stop eventually, but note that I'm going much bigger on rotors with my Simplex and larger rotors are better on any bike regardless of weight and stop quicker. Big (203mm) dual rotor up front really stop the heavier builds and are popular with chopper style builds with built motors especially. They don't really look classic on vintage style bikes but they dang sure work well!
Rick C.
