Bike builders that have machine tools/shops
EZL
350
686
93
Chenoa, Illinois, USA
Good info Dennis the Lifan is a 5/8" shaft and I used a 3/4" adapter to fit the Comet CVT. So the Gas bike transmission is designed for the 5/8" shaft engines? I'll check them out. Thanks!
Rick C.
Be real carefull on a CVT it does use a lot of HP to run but once it's spinning up it's a good situation.
No jackrabbit starts! You should see a BIG Difference in performance. That CVT amazes me with
how flawlessly it works and how smooth it responds to the throttle. The biggest temptation is the
worse, don't ever hammer it especially with the 212. The 79cc would be a welcome addition to
biking using a CVT! The Lifan engines have a transmission which would be a plus maybe not in a
torqued takeoff but a good cruise speed. The only thing better than a 212cc would be a 420cc
which would guarantee a breakage on the bike! If you are crazy go to a "Stage 4" setup and do
20 hp like the gokarts do! (^) .rd.
Dennis
EZL
350
686
93
Rick C.
Rick, use the 1" drive unit for the CVT, get a adapter to the 5/8" but the 79cc engine has enough torque to snap the
crankshaft off! I guess a fella could dog-it-around and be ok? How do we know what that is posted until it's tried?
A lot of trolls and disinformation out there and we are the only only ones experimenting!
Tom from Rubicon
2,840
6,128
Rubicon, Wisconsin
A little caveat emptor Rick and Dennis, unless Gas Bike has changed vendors the die cast aluminum mounting plate of their death row CVT had knit line at which they broke or did. A guy I worked with built a Huffy with a death row kit, it was fast until it broke (often) but that was not the demise of the Huffy, the coaster brake broke internally and locked and he limped pretty good for about a month from lose of hide.
Tom from Rubicon
2,840
6,128
Rubicon, Wisconsin
After a brief thunderstorm this mourning, to celebrate completing 50 years as a Tool and Die Maker my wife and I took breakfast at Diner 67 in Lomira, WI.
Once home into the den of labor. First job bore the 41b13 sprocket I.D. to 770" so as not to drag on the pedal shaft. Then faced down the hub to 250" height ( this is the offset I hope will bring the drive chain into line with the drive sprocket). No mounting holes yet.
Yesterday, I made two 1" high stand offs for the front fender stays and bolted them up and I had more than 1/8" clearance with the axel fork so today I faced off .125" and still cleared the fork by at least .062" which is huge in a rigid assembly. Next were the rear stays and I knew it would be challenging and it was a bit. Not cutting 45 degree corners on the end of the stays until I made the cuts. But it is done and stiff and steady.
Well this last Thursday all chains mounted and tracking beautifully and I am thinking any good weather on the weekend is seat time. But as I am there sipping a barley pop looking at the fork wheel assembly and my mounting the fender to the un moving steerer fork and considering the conversation Rick and Pete form the UK had about possible over travel of the CNOL Girder Fork I see an endo in my future with my set up.
Home from work I went directly to the shop, dropped the wheel, unmounted the fender, and fab'd a L bracket to top mount the fender to the moving fork. Next will be fender strut mounts clamped to the front sprung fork.
Thought it might get done Saturday but things that are not hobbies came first. Including Vietnamese Pho for supper.
FOG
282
617
93
72
I was pedaling along the other day when a motorized bike cruised right past me. Phatmoto on the tank and teeny little rear wheel were about all I had a chance to see, and I wanted a better look at it, but what could I do? It was a downhill road and I was already in 6th on the big ring. I tried ... but he just kept gradually getting smaller.
But there was a clue. :) He had bags of cans hangin' from the bars! I knew where he was going and caught up with him at the recyclers.
It was a bit on the scabby side of life. The rear was a little 10" mag from what I don't know that didn't get anywhere near the rear rim brake, but he had a disc up front.
The jackshaft was just about the cleanest thing I'd ever seen in that it was mounted right thru the center of the seat post. With a guard on the primary side covering it ya couldn't hardly tell it was there. Got me thinking about my Schwinn ....
4 stroke centrifugal motor with no brand name but a sticker said 79.5cc's. Would that be a Predator? Huasheng maybe? Are they one and the same?
curtisfox
6,077
4,041
minesota
Don’t think huashenig makes a 79, but harbor freight sells the predator so cheep, with coupons. And are good motors, go-kart co’s sell parts for them for hop-up. They are Good motors, equivalent to old Briggs powered bike of years past, only higher reving. Should go about 30, 35 miles per hour. Back in the 50’s I did a 1 1/2hp Briggs, it did 30 mph .......Curt
indian22
4,734
7,740
Oklahoma
Yeah FOG the Predator probably and it's proven to be a good bike motor option. The Lifan 99cc is a single speed vertical cylinder commercial lawn tool type engine , no transmission; not the go cart/ATV type with transmission. Unlike the 79cc Predator I know of no speed part availability or even how good a motor it is...just bought it to play with.
Rick C..
Tom from Rubicon
2,840
6,128
Rubicon, Wisconsin
Back in the shop for a bit essaying the needs mount the Wald fender on the front springer fork. Bear with me guys, but my master Ray Nystrom drove into me to visualize and so I have for years before computer software could, and I am finally seeing that in my original attempt of hanging the fender to the steerer as earlier posted.
But after starting the relocation of the fender to the front fork I started to analyze/visualize the dynamic moment of the fork and fender as opposed to frame, fork moment which is not as active. I think for now I will trust the Wald fenders and struts. I need a annual replacement of stressed parts which is very doable. As you al know I still pull a 40hr week so what gets done is after work and barley pops too.
indian22
4,734
7,740
Oklahoma
Tom some top builders on this forum have shown and written about how difficult hanging safe and good looking fenders on suspension forks can be. The original source of fender design inspiration comes from the early day manufacturers themselves. Study the early Indian & Harley bikes for examples of fitting good fenders on various styles of spring forks. Fitting wasn't easy or haphazard, but they got it done and they were heavy duty affairs for sure.
The Indian leaf spring seems among the harder spring designs to correctly fit a fender on. Though the various coil designs posed their own problems. Most commercial suspension bicycle forks don't allow a lot of room to work with, unless you go to modern mountain bike suspension forks' or run 24" wheels on 26" classic style suspension forks. A few have increased the length of the fork legs to gain the room required, most have just worked the fender designs to fit what exists in the way of forks.
Giving it much thought and careful execution is a good way to approach fitting a front fender. In the meantime constant vigilance pre-ride and maintenance/replacement routine is very wise Tom. I've only run a front fender on one build over the last ten years and about a dozen bikes so I'm overly cautious for sure, but a good fender is both useful and sometimes a very attractive addition to road style bikes, classic style or otherwise.
Rick C.
Tom from Rubicon
2,840
6,128
Rubicon, Wisconsin
I have no empirical data to work with, my original setup might have worked. But I don't know how much travel there is in a Felt fork.
It would be possible to jam a tire with out fenders in a extreme case but I don't know.
I would love someone with empirical data to chime in on Felt fork travel.
Indian leaf spring suspensions' were interesting but there was a gap in the fender. Harley's had miles of room for tire rebound room.
Well I feel better with that tirade off my chest.
Back in the shop for an hour after work starting to machine two fork fender strut mounts. Most of the rough work completed today. Tomorrow, a bit more Tuesday.
EZL
350
686
93
Dennis I like your spirit of try it and .see. I haven't built a 4 stroke with CVT on a bike yet, but have done various go karts using both. The CVT is a game changer for final drive sprocket size though. I'm pulling for the 20 tooth to work for you, but that's pretty small.
I bought a Lifan 4 stroke vertical engine, think it's a 99cc, 3.5 hp about a year ago and put a comet CVT on it...bolted the thing down on a work bench and ran it for a couple of hours over the course of a few days to break it in. It's been waiting for me to get back to it ever since. I thought a 44 tooth would work with the CVT, my 175 lbs. & our hills, so I'm interested in what you find to work with the 212cc.though the Lifan has much less power and torque than the Predator 212.
Rick C.
Rick, I had some time off and went ahead and put the 20-tooth sprocket on Sunday. The thing was a real bugger to get the
chain to align with the sprockets. I finally got it as close as I could and couldn't try the bike till Monday night. The engine
wasn't fazed by it even taking off from a dead stop. The sprocket is a little slow building up and I suspect that the CVT
wasn't fully engaging with the belt. I revved the engine up and the engine was slipping the CVT belt. I could ease into the
throttle and it was alright. Normal cruise speed of 25 mph was wanting to climb over 35 mph. The engine can pull the
sprocket but the CVT doesn't like it. :rolleyes: I am thinking the belt has a little wear on it and I think it is stretched a little to slip
like that. My opinion on using a 20-tooth sprocket, don't do it, it's hard on belts and acceleration isn't there since there is
belt slippage. The sprocket also isn't easy to align. I put the brandnew belt on and it is better quality and fits tighter. I went
ahead and remounted the 32-tooth sprocket and a 30 or 28-tooth might be a compromise? The 32-tooth is wicked as it is.
You have good acceleration plus 30+ cruise speed. Running 30+ the bike will set you back and climb way past 50 mph.
My mechanical speedometer has been right since I put that engine on this bike. I doubt if a steep incline would bother the
bike. I know the 49cc can pull a hill over here but acceleration on the hill running about 25 mph it was sluggish whereas
the 212cc isn't fazed by the hill and accelerates with very little throttle applied to the engine on the hill.
I wouldn't run a 44-tooth on the 212cc and I doubt on a 79cc coupled to a CVT. The 36 and 40-tooth sprockets are
dangerous on the 212cc and will tear things up on the bike. The first time I came down on the throttle on the 212cc
and it was nowhere near top end of the throttle running 25 mph, the bike lifted the front wheel. These bike frames
won't take that! I've never opened this engine up full throttle since I removed the governor and the low-oil sensor
on the engine. I figure, if a fella can run 60 mph with a stock 212cc with 26" wheels and a 40-tooth sprocket, it's
fast enough! The Predator engines have the torque and rpm to get you down the road. I've got the Stage 1 kit on
this engine and I wouldn't go any higher. You have to have heavier hardware to go any higher in HP. What would
be fun would be to go with a "TrainMaster MB200-2 mini dirt bike" and a 212cc Tillotson Hemi 10 hp engine. :)
If I was you, I would go ahead and bolt that 79cc and CVT on a bike to try it. A good starting point would be a
40-tooth sprocket although since you already have the 44 give it a try.
Dennis
EZL
350
686
93
Rick C.
Rick some of the fellas have had the bushing cause problems. One fellas I think had a solution, go with a 1" drive pulley that
was meant for a 420cc CVT and then get a thicker sleave to size it down to 5/8". Then, some of the fellas have had the
crankshaft break on the 79cc? The again, some fellas can break a steel anvil with a rubber mallet;)!
EZL
350
686
93
That would be a scary situation to hit a pothole running 30 mph and have the suspension bottom out on a fender!
A lot of fellas warn about running fenders on the motorized bikes since they can come loose and jamb up things!
EZL
350
686
93
Rick C.
They are good in the rain and going through mud puddles! (^) I try to avoid riding in the rain and a basket on a rear carrier
will keep mud and water off your back. :)
Phatmoto is being sold by GasBike and Kings Motorized Bikes. I don't believe the engine is a Predator but possibly a Huasheng?
The bike build is on aluminum and it is built good. I don't know about the engine and whether it is all that good. There are reviews
on YouTube and one fella wasn't pleased with the speed of 20 mph. The problem with that engine is the availability of performance
parts. A Predator on that bike would be a good combination. The mounts for the engine and the jackshaft are well done and are
gusseted.
EZL
350
686
93
Rick C..
One of the Lifan 125cc with the semi-automatic shift transmission would be a HOOT on a bike!
EZL
350
686
93
I wouldn't trust the Huffy frames and the use of a coaster brake on the 212cc. I am having some luck with the the mag
wheels so far so far but need to get a set of disks on that bike. Got so many things to do on it and not enough time and
money to do it!
Dennis
Tom from Rubicon
2,840
6,128
Rubicon, Wisconsin
Hi Dennis, I have read a bunch of fender catastrophizes and the is why I went with Wald.
Think https://bikehistory.org/bikes/typhoon/
My Huffy Davidson fender and struts are a little slighter Ga. than Chevy Vega body work. One of the Tool and Die apprentices I served with bought a Vega and we put thumb dents in his car.
Tom from Rubicon
2,840
6,128
Rubicon, Wisconsin
Home from work and in my shop today turning the aluminum 2x2 square block to make the fork clamp/fender strut mounts. I didn't have round bar stock the right dia. so square stock will do.
I blew through a hole and drilled to .875" and mounted it to an expanding arbor to finish the OD work. That is done.
EZL
350
686
93
LOLs, yeah Tom like the new "cookie-cutter-cars" of today! :D
Dennis
EZL
350
686
93
Took the bike out late this afternoon to make sure everything was ok and it had the 32-tooth back on it. I had a farm
dog running along side of me and he looked like one of those Australian Dingos can't remember the name of them
but he could really run I had to buzz up to 40 to get ahead of him. He was just playing around chasing and racing
me. Real nice Fall day and it won't be long the weather will go to heck and the riding will be done for the year. :(
Dennis
