OK here's an update. Instead of starting a new thread I'll just continue the story here lol. I never got the issues squared away on the first engine, since amazon refunded my money I just bought a new kit. My plan was to just swap the engines out since I had everything installed already and maybe use the blackberry engine as a backup once I bought a new top end for it.
I bought a runwell pk80 that had some port work done and a few upgrades. It was on sale. I got it swapped over and it runs poor until it gets up to around 18mph then it runs great. So around 18mph and and up it has tons torque, and very responsive. It's faster than my other pk80. At low speeds it's jerky and I believe sputtering is the term. I have to give it wot to get up to speed and it's slow to get there. I combat this by feathering the clutch at low speeds but it still runs poor.
I ran 1/2 a gallon using opti 2 50:1. Now I'm running 100:2 with no difference. I know this can be a controversial oil to use and I admit 2 out of 3 motorized bikes that I've installed have ran poor. First one has around 150 miles on it and runs so smooth. I am new at this and it probably user error, but learning has been fun. So anyway, I had all new parts from the second kit, some are nicer, so I just went ahead and tried to troubleshoot. Nothing has helped. Here's some things I've tried.
Changed muffler and gasket. It had a leak at gasket.
Sprayed starter fluid where cylinder and intake meets. It revved up.
Changed intake manifold and gasket. Manifold that got swapped out looked like it wasn't perfectly flat.
Added o-ring to carburetor/intake
Changed throttle cable and grip. Reason is, I had an issue with the cable sticking.
Changed cdi, wire, and spark plug boot. Tried 2 different spark plugs, B8HS and stock runwell plug. B8HS came with kit as an upgrade but I would think that's too cold of a plug. Plug boot is ngk and wire is good stuff.
Changed fuel filter. First one had a leak.
Made sure tank had good flow
Tried both nt and speed carburetor.
Torqued head bolts to 12 pounds. Rechecked.
Moved clip up to top notch on carb needle. It has 4 slots, it was 1 down from the top.
It could very well be just running poor becauses it breaking in. It probably has 40 miles on it. I didn't experience this on my first pk80. But it did continue to start running better and better as time went on.
If it had a air leak, or loss of compression, wouldn't just run poor no matter the rpm? Like I said this is just happening at lower speeds/rpms. Any insight would be great. Here is a description of the kit upgrades that came with it. I'm using a 44t sprocket instead of the 41t.
