Installing a disc brake / sprocket combo is very complicated!!!!
The adapter that Tom linked will work, but you'll probably have to switch to a much larger disc & then use a super small sprocket so the chain & caliper don't hit each other, (because there's not enough room for them to be right beside each other), & then you'll most likely have a gearing that's too tall for your liking. & then you're probably going to have new alignment issues with both the sprocket & caliper that will need modifications to fit properly.
The easiest (& least expensive) way to get your bike going is to use that disc adapter for the new sprocket & then change the brakes to 'V-brakes'. (you already have the posts welded to the frame for them).![]()
I made a quick and dirty way to shift over the disc brake until i trashed the idea and built a custom jackshaft. The thing ya do is take some bolts and washers and offset the disc brake rotor to your needs. Then do the same with the actual rotor by cutting some scrap steel and fabricobbling something up. Keep the stock disc brakes and offset them if you have clearence issues. the cost is free but if you didnt have the scrap stock it would be 1.89 dollars.66cc,
Do you have access to a machine shop?
I made a Disc Hub Sprocket Adapter on another build, using my lathe and Bridgeport mill.
Using 7075 T6 is recommended.
As for the lock... McGiver it
66cc,
https://motoredbikes.com/attachments/img_0396-jpg.82301/
https://motoredbikes.com/attachments/img_0395-jpg.82302/
I will tell you. B.c I am 16 and dont have the cash, I had to built my own jackshaft kit from scratch. Bought some bearings, a freewheel, some 5/8 rod stock and cut off the chainrings from an old bike from the junkyard.bike4life,
This is exactly what I had in my mind, but with the limited clearance, I was thinking ofsetting the disk would require some frame bending or something.
Did you have to buy a bigger disk, I see that youve used a fab metal for the caliper.
Dude, can you share you custom jackshaft!?
I would love a jackshaft on this build, it has 9 gears!!! I was thinking this thing would pop wheelies easy if I had that.
Can never get my head around paying more for a shift kit than for an engine kit.
