I have an additional wheel and tire to mount on the back as a spare. Both have hubs drilled for mounting disc rotors. So the car wheel will be equipped with a disk brake, foot operated brake pedal mounted on the car frame.
Kayak body is approximately 26" in width, 16" in height and length 6' to 6-1/2'. With 4" ground clearance on the car frame the total rig height shouldn't total much more than 22". Adults will need to be very limber to get in & especially to get out, but the grab bars should help. Easy mount for a Lab though!
Bike wheelbase is 53".  and I'd like the car shell to not extend past the rear or front wheel so 6 & 1/2' length at most...
Outside width looks to be about four ft. from bike frame to out side of wheel hub; Primary reason is the kick starter has to clear the shell body & the wheel torsion spring requires 8" extra before adding the wheel. Not knowing if this is an abnormal amount of stick out for a rig or not, but it's 8" wider than I'd estimated earlier.
I should have the both the leaf spring & the torsion spring in hand ten days from now. I've also  narrowed my kayak donor shell down to three choices, all 8 footers.  Though I found one 10  foot that could be easily cut to fill the bill. It's 4" wider though. I'm really not in a hurry on the Kayak shell 'cause last year they were discounted significantly after the holiday season.
I've considered this particular project for more than two years now and feel that it's going to be lots of fun putting the pieces together and scary as **** testing the beast...The alligator gar car may take more than a few bites out of the Old guy!
Rick C.
