2016 EXCELSIOR Board Tracker Flat Head Build
lol, Ludwig you crack me up! Jeff the bike is also lovely & I'm certain your head is well formed as also. Rick C.
Got back on the list of items for this bike, wheels are in the works, seat pan build started, and waiting for items to show up for the motor: New cam, springs, valves and a tad bit longer billet rod. Flat Head Fever....
How effective is the shock seat suspension? Can you go on long rides without back pain the next day like with a spring seat only setup?
Nice work.
Had a nice board track bike built by someone else, looked great, built great but no suspension...kicked my ass to ride it, suffered for days after...sold it and moved on. This bike will be easy on the back with the seat and fork setup. Working on placement of the shock so I can adjust if needed.
The go fast parts came in, 7500 rpm package should do good. That rod is so cute...lol...too bad it's hidden in that block. Time to get the die grinder out and clean up the ports....
Just had to add that last picture...my true passion is the Dyno Cruisers... #nomoremotors for me....
Back on the bike project, waiting for a few items that were not delivered with my orders but must move on. Started with a design for bars, if I chose to use internal throttle and brake I need 1 inch bars, committed to do it now...Have 1 inch stainless to make the bars...lets see what happens. Pictures are moc ups of Dyno bars with stainless ends...what do you guys think?
The bars nicely complement the curve of the straddle tube and tank top as well. The bars shape also draws the eye to the radius of the springer tubes. Length looks appropriate as well. Simple and elegant addition to your nice build. Rick C.
Thanks for the input Rick, I have looked this over and will build these bars but will do a modified version of the felt cruiser bars with the cross bar also...happen to be my favorite with the limited supply in the market.
Well a couple updates to this final final final build...lol The rims are done and really like the setup..front radial with no brake, rear disk setup. The rear will have something special for brakes. Got all the motor parts and will start on the mods this weekend. I am happy with the bike so far, should ride real nice.
Got the seat done yesterday, it took a lot to get it the way I wanted. The mounting bracket was all out of wack to that needed to be cut and re-welded. The pan has about an inch of adjustment back and forth, the seat post can also be raised for seat adjustment angle.
Bike off the stand for a front tire change to match the back one, a few pictures too.
As always..soo nice..seeing how the bb is position ed above the frame..do you think removing down tube and chain stay on a crusier frame and and bending up a double downtube sweeping low would workout?
Thanks Scratch, I think you could do it if you have the means and if have the means why not start fresh and build a complete frame? Do your own design your style.... Go for it!!
A little update on the bike, got in the rear brake setup and have to say it's nice, cable operated hydraulic caliper. Just what I wanted. Also was able to work on the Adjustable ignition...all done on that item...
Been on the recovery from pneumonia but bored as ****, making a little progress. Motor work on the agenda for now, got the ports all cleaned up, new valves, new billet rod and the cam in place. Now this little fuker is trying to suck the blood out of my hard work.
