I had to think about this for a while, but understand now. The pedal start ia right side chain. Top tension on chain. Then from hub of wheel transfer to sprocket left side. Then chain is bottom tension trying to jump start engine.
Can there be a pull recoil start and engine idles with auto clutch?
The need for a chain tensioner, could it be eliminated?
Beefing up the metal welded to hold the tensioner and adding gussets somehow, is that something that is wise? What I mean will it take out something else as a result of one fix. I don't mean to be knocking what is already there, but do you know if others have had any issues with similar.
If you have picture to show how the chain with the tensioner is from front to back to see how aligned it is, I would be interested. What I mean does the idler wheel on the tensioner only keep the chain raised up and not guide away from hub sprocket.
Forgive me if I don't know much about the chain drive, I've always used v-belt and sheave. Chains I use are of very short length on jackshaft.
MT
Oh before I forget... really nice build... the gas tank... how you make custom cable ends!!!
There were a few things at fault that I should have saw coming.
1 - Compression ratio has been raised to somewhere around 11:1 (It's a guesstimate. about 6cc combustion chamber) And because of this, the "pedal start" is a lot more violent and harsher on the bottom chain. Now, the head DID come with a decompression valve, which was the whole reason I bought this particular Puch head but realized that the hardware is missing and I can't seem to figure it out.
2 - The chain tensioner is more or less needed for clearing the rear-bottom left tubing. I made the engine mount intentionally low for center of gravity sake and this was the result.
3 - The tensioner was alligned, but the steel sheet I used wasn't thick enough to take the "pedal start", bent, tensioner went out of wack, and the chain derailed from the sprocket.
4 - The tensioner was too close to the sprocket, making it vulnerable for the chain to eat the sprocket. It seems the sprocket don't want any more than half the circumference covered in chain.
Tommorow, I'll make a new tensioner out of thicker material with a better design, this time, a short tensioner closer to the tubing and out of a square tubing for the sides to act as a gusset.
