As long as you know what you're going to have to fix and why, no reason you can't fly.Maniac,
Thank you for the link to that thread! That link lead me to another link that lead me to another with some great info about the various Cag performance stage mods. And that leads me to conclude the Cagllari is a fine engine to modify for performance provided one has some understanding of the baseline engine weakness, and the crankcase is a major weakness, specifically the cylinder studs (or lack there of of studs).
So I ordered a spare stripped crankcase and will build the stage motor from that, to include larger cylinder & head studs of at least grade 8.
Don
Oh yes! I hear you on that! Exotic motors get the juices flowing, which is mostly why I want to try my hand at it. It's a side project, not something I would build to sell. It will be for me (only) so if it blows up, no big deal... but I will try to build it right so it doesn't blow up or pull itself apart.
16v4,It's way cheaper to buy an assembled "stage 3" engine and rebuild it than building one from parts. Since these are Chinese, there are multiple factories with different parts dimensions, so getting an assembled and running engine is a good way to ensure all the parts are from the same factory and will work. You should be able to build one from parts, but be careful with all the clearances.
A note about the reed valves, the stock metal ones will fatigue over time and cup, eventually not sealing the intake properly. That also have a tendency to fatigue and break off and munch motors. The cheap cf reeds work well and can be limited in their bending travel by a cut down metal reed. The limiter makes the reed last longer and can be used to tune the spring rate of the reed as well.
An interesting plan with the nut inside the case. They already make the nut:Today I received the new Cag stripped crankcase, along with the crank bearings and crank seals I ordered. Looking over the crankcase halves I see the the case cylinder stud holes are not blind holes, rather they are through threaded holes and it appears possible to open the holes up and rethread to accept 1/4-20 or 1/4-28 grade 8 studs and put modified (turned down) nuts on the back side of the studs to prevent them pulling out the case threads rather than Helicoil the case. Still, Helicoil is a viable option. Will have to make a decision on how I want to proceed but it is nice to have options.
Don
FFV8,An interesting plan with the nut inside the case. They already make the nut:
http://holokromefastenal.thomasnet-navigator.com/viewitems/allen-nuts/allen-nuts-heat-treated-steel?
As you note, I am already committed to the Cag i.e., too much invested to change course now, not to mention the liquid cooled 39cc engine seems to suffer reliability problems too. China 2 stroke motors seem to share reliability problems.Realizing you have laid the ground work for an air cooled Cag adventure I just thought I would throw this out there for consideration. Seems like a cheaper way to a true hi pro engine. This one doesn't have the specs listed but I seem to remember 13k rpm and some pretty healthy ultimate HP. Small radiators can be had used. I bought a KX65 version for a project I have waiting for $20. Just a thought.
http://www.ebay.com/itm/39CC-Liquid...ash=item3f5822260a:g:tUEAAOSwu4BVsBBY&vxp=mtr
16v,I like the idea of using those Allen nuts. I had to lathe down the OD of M6 jetnuts to make them fit inside the case. These motors have a sound internal design but make more combustion pressure than the cases can take at the head bolt holes, and they vibrate which causes it to walk around too. Great light little motors though, and if you don't try to bog them with tall gearing it should last a while before blowing up. Im hoping mine provides a lot of riding time, I've been saving the hours on mine and riding carefully because it took a lot of work getting it to hold together.
I will keep you posted re: my Cag motor build.I'll be paying attention to how your motor strengthening works out, since I would like to someday make a higher comp ported motor based on the relatively affordable stage 3 motor. I think that a base model cylinder cag engine rebuilt with the hardware upgrades would probably have longevity on par with the utility 2 strokes for pocket bikes, which are quite a reliable engine. The reeds on the cag fill out the powerband better than the piston ported ones, so you can cruise with lower clutch pickup rpm. I feel like the cag is a bit more refined of an engine than the Mitsubishi clone, it really performs well for the price, so reliability is really the only obstacle with its use. Some have claimed to build cag motors that make around 10 hp, which is quite incredible considering the engine only weighs 7 lbs!
