New to the motor bicycle world!
SuperDave
179
Panama City Beach, Fl. USA
Great advice! The only problem that i had with the coaster brake was that it burned up so quickly (almost like the previous owner didn't have grease in the hub) i dont mind having rim clamps so i might go with that but not too sure yet.
The ONLY way I would run rim clamp brakes is if I also had a coaster brake. There are a lot of posters here on this site that will tell you coaster brakes are a bad idea on a motorized bike. If that is all you have, it is better than no brakes. They heat up too fast and cannot shed heat, cooking the grease & frying the bearings in the process. Rim clamps apply the friction over a much larger area that is able to shed heat away from the bearing or grease, but require more force to equal the same stopping power.
By running both hand brakes & a coaster brake, you have esentially a foot powered emergency brake. For normal stopping you squeeze the handle to slow down & stop, but you also have the option of back pedaling for a panic stop. You don't want to use a coaster all the time, for obvious reasons: It's brutal on the hub & bearings, it can easily lock up in soft sand or gravel, and locking it up can & will wear flat spots on the tire, resulting in a subtle wheel vibe that magnifies at increasing speed. Use it only in emergencies when you need to stop NOW! I would rather pay $50 for a new flame tread tire than a thousand dollar hospital bill, on top of a ruined bike and damages to someone's vehicle.
Servicing a coaster brake is also more labor intensive compared to rim clamps, you have to dismount the wheel & chains just to gain access, disassemble the hub, then there's realigning the wheel properly so the gears won't bind the chain. That can take as much as an hour or more, whereas servicing rim clamp pads is 10 minutes with a single wrench.
Now disc brakes offer a superior solution, they shed heat better, require a fraction of the grip rim clamps need, they are easier to service compared to coasters, and can lock up enough to throw you over the handlebars. The only downside I can report is disc brakes are noisy, mine moans when applied. But that's a small price to pay for the ability to stop on a dime & give you back 6¢ change. I have no experience with drum brakes so I cannot say one way or another.
KCvale
3,966
57
48
Phoenix,AZ
I have heard Schwinn is getting back to quality again but don't know for sure, I haven't built on any new ones but I just in took an old classic Schwinn to rebuild with a simple 2-stroke direct drive for a 'down on his luck' guy that lives in my general neighborhood.
I have simple advice for new builders, start with a good bike and go from there.
If you go cheap with poor installation for the motorizing no biggie, pull it off and you still have a good bike.
Go the other way, well, if you start with crap it will always be crap.
Cgk_iii
23
San mateo
so finally some updates.
Installed a manic mechanic sprocket adapter and a 1.95 rear tire. no more chain eating my tire, hooray! Searching for some rim clamp brakes right now. After brakes, im going to start doing some performance upgrades. i fixed the weak points on the frame of the bike and now im back to riding reliably.
will post more updates once parts arrive!
some pictures:
Untitled by cgk325i, on Flickr
Cgk_iii
23
San mateo
so after enjoying my bike for a solid month, something bad happened.
Remember when i said that these huffy frames are really weak? Well take a look at what happened to my swing arms...
Clean break. It almost looks like someone took a cutting wheel and cut the swing arms lol. Like i said before, im going to have to get a new platform and swap everything over. Will probably get a new bike by the weekend. I will keep the thread updated as much as possible.
Happy Riding!
Chris
mapbike
5,502
109
Central Area of Texas
I have a Huffy karaoke that has been bullet proof since 2010, seems the most trouble with the Huffy bikes is the Panama jack version that has the cargo rack welded on like yours, looks to me like the area that has been welded on crystallized the steel right below the weld which makes the metal very brittle, I'm guessing that is what caused yours to break where it did.
Even though several of us have had great service with our Huffy bikes, there is no doubt that they aren't the best choice out there for motorized bike builds.
A Schwinn like this one would probably make a nice build
http://www.target.com/p/schwinn-men.../-/A-15287656?lnk=Rec|pdp|viewed_viewed|pdpv1
Firmstrong is another brand i think will make a good build, they have several models but I like this one because of the colors..LOL
http://www.ebay.com/itm/Steel-Frame...959?pt=LH_DefaultDomain_0&hash=item27ee9c0d3f
Cgk_iii
23
San mateo
update:
As i was driving down the road the other day, i spotted a garage sale, only a few blocks from my place. He had a few bikes sitting outside, so i got out and picked up a blue schwinn road/cruiser style bike. i will have to snap a photo of it this weekend.
I already got the motor mounted and then ran into some issues with the rear wheel set up. I wanted to use my coaster hub wheel from my old huffy onto my new bike only to find out that the axle length is too short, but then noticed that the 'Heavy duty' wheels from bikeberry have a longer axle (about 180mm).
To get a better idea, the distance between the inside of the swing arms (where the axle sits) on the huffy is about 4" and the distance between the swing arms on the new bike is about 5" There will be about a 1/2" gap between the hub and the new bikes swing arm, so i will have to use a spacer to compensate.
Also another issue is that the pedal is hitting the motor. Either i am going to fab up some new pedals or grind/bend the existing ones. Anyone have experience with this?
will update soon with pics.
silverbear
The Boy Who Never Grew Up
Jul 9, 2009
8,325
670
northeastern Minnesota
Some years ago I had a 63 Schwinn American Deluxe and installed my first China girl kit. What a learning experience that was. Like you, I found the pedal crank did not have clearance with the motor... just a wee bit, but enough to make it not work. Someone suggested trying a crankset from a bike made in Japan or China as they are a little wider. I did and it was enough to make the difference. So, I would suggest installing your crank from your old bike, to see if that does the trick. You'll need to swap the whole thing since the threads will be different if the Schwinn was made in America. If it was, congratulations on a good choice for your motorbike. Don't expect breaks in the frame if it came out of Chicago. I do know that after Schwinn was sold and came out of Taiwan that those bikes were also well made as I had one and was pleasantly surprised at the quality. I have no experience with the Schwinn currently being sold, I believe out of mainland China. Good luck to you.
SB
Cgk_iii
23
San mateo
SB
This is an older schwinn. I will have to do some research on how old it really is though.
Your suggestion about swapping the cranks would be ideal, but there is no way that will happen. The crank on the huffy has a way bigger diameter than the schwinn crank. Ive looked at other options, such as, the wide crank pedal set from one of these motorbike sites, and im not sure those will work either with how small the diameter is on the schwinn.
back to the drawing board.
silverbear
Jul 9, 2009
8,325
670
Are you referring to the diameter of the sprocket? They should switch okay. If you mean the diameter of the pedal rotation then that's another matter.
SB
2door
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
When you said you have a " blue Schwinn", it makes me wonder if you haven't stumbled on a Jaguar. How old do you think it is? Does it have a metal head badge with rivets or a sticker? If it is a Jag you have a good platform for a new bike.
Post a photo of the Schwinn for us.
mapbike
5,502
109
I was thinking the same thing Tom, when he said blue Schwinn the Jaguar came to mind, I wish I could find a couple of those bikes myself.
Cgk_iii
23
San mateo
i wish it was a Jaguar..
just finished up the build. bought some parts to upgrade, such as:heavy duty wheels, wide pedals, and a new gas tank.
heres a pic:
Untitled by Chris Kallas, on Flickr
Cgk_iii
23
San mateo
finally getting around to updating this thread. I was able to enjoy the blue road bike for a good 3 months until this happened:
I didnt wait long before getting a new frame
i wanted to upgrade the suspension on this new HKS so i can prevent things like that from happening again, so i purchased some cheap 29" threadless suspension forks and converted the headtube from a threaded system to a threadless system
