Can anyone help me and tell me how to shim front 10 tooth sprocket and rear sprocket on a hub clamp? Any tricks other than offset engine.
A second sprocket....????a second sprocket will work best if you need to keep on sprocket mounted on the dust cap to center it provided the bike frame furnishes room for that and washers to space it
I suppose that could give a bit more clearance. But it sounds like a risky idea to me.a second sprocket will work best if you need to keep on sprocket mounted on the dust cap to center it provided the bike frame furnishes room for that and washers to space it
Just FYI, take everything this guys suggests with a cup, not a grain of salt.a second sprocket will work best if you need to keep on sprocket mounted on the dust cap to center it provided the bike frame furnishes room for that and washers to space it
Ditto...... on all points made.You can't shim the front 10T out in the engine enough to matter.
If you have a fat back tire you need to remount the engine out to the left.
That is why it is usually best to jackshaft a fat tire, the engine can mount where it should.
A clamshell back sprocket will let you do lateral chain alignment at the back wheel.
hmmm......it's not easy to deliver a message like this without seeming harsh or confrontational.Dear Boygofast.
I am writing to ask you as politly as possible, while also trying Not to be rude. To PLEASE quit giving advice at least untill you have tried most of what you advise.......
........Please read and LEARN from the valued members......
............dont get mad, get Motor Bike educated.
Thanks for reading
fatdaddy.![]()
This skull and crossbones?I have basically same bike in the photo I uploaded and it has the Maxxis Hookworms with no motor movement.
No that's just the pics angle. Its a chain drive transmission not really a jackshaft.Cannonball2 that's interesting! So you used a 3 speed hub as a jackshaft? Is the hub riding on the wheel? It looks like it's touching the wheel.
Nice build.Thanks KC . Do you mean a Nexus 3 speed hub? And a Jackshaft? Here is a orange version of my bike with 2.5" Hookworms.
Yeah map, here we go again with more boygofast "EXPERT" advice.A second sprocket....????
