Its not the Echo oil, the oil Echo puts its name is excellent oil, you arent gonna get it right until you jet your carb down some, plain and simple.
all the other things you try won't fix a super rich running condition, put a new spark plug, rejet the carb and keep running the Echo oil, you will be waisting your money going to buy a different oil 2hen I can garrantee that has zero to do with why the plug is so black and oily.
Second thing is running a super oily mix for a break in period being neexed is a myth, I start mine up on day one with a 100:1 mix of Opti2 run it for just a few miles to make sure everything is right on the bike and that everything stays mounted as it should and then before the firat tank is even done I ring it out and ride it like I plan to ride crom there on out.
I put about 12-15 miles of easy to moderate running just making sure things are right and then run the dickens out of it after that, I jet my carb down to where I think it needs to be before I ever start a china girl for the first time, to be completely honest about 95% of the "breakin" stuff I read on here is 2hat we call "hog wash" down here in the south...lol Just extra trouble with no benefit at all if things are done right the first time.
Again, reduce the main jet in the carb, adjust mix ratio to 40 or 50:1 with the Echo oil in Regular unleaded ggas and you'll see it come alive as long as you getting a good strong spark and engine has good compression.
Sick Bike Parts has replacement jets if you need to buy them, some of us here just solder our jet  losed and then redrill with a proper wire gauge bit until we get the deaired tune for our set up.
