OK guess Im doing an Experimenting series kinda like the Dummies books thing.
So now its carbs. I have tried tuning the stock NT to some success and the RT ditto. I could never get the NT to run cleanly over the entire range. I believe the issue at least with mine is the needle profile. Jetting affected the running as expected as did raising or lowering the needle. Ran ok but never super. I got the RT to run pretty cleanly but it was always sort of mushy down low and was VERY cold natured taking a long while to warm up and run well. The lack of a venturi I believe contributes to this. Carb has to get pretty warm for the fuel to atomize well.
So now on to another carb. If you are expecting a hi-pro carb you will be disappointed. This is a carb with excellent running, easy starting, and superb idle. Right out of the box! It has a 12mm venturi so its smaller than most on MBs. This is what makes for the excellent throttle response I was looking for. Runs cleanly from idle(even extended) til it runs out of breathing around 28mph. That's only 2mph slower than the bike went with the RT. A larger main might regain that. It has and adjustable idle mixture which allows excellent low end acceleration due to the fact it can be adjusted a tad on the rich side. Idle is spooky low. Sounds like a heavy flywheel enduro bike. So what is it?
This: http://www.ebay.com/itm/Carburetor-...Parts_Accessories&hash=item58bf227ca3&vxp=mtr
I haven't seen a lot of info on these here, maybe I searched wrong, But if you are a rider like me that's interested in a good running stock CG, this is my best carb so far. Wont be much fun for you guys trying to squeeze 10K out of a CG.
Ignore the hastily thrown together look. It was just to try it out. Will add an enrichener cable and a proper cap for the vacuum take out nipple as well as an air filter. Didn't want to spend a lot of time if it was just going to wind up in the junk box.
Note: the opening for the manifold is 20mm. The sleeve from an RT fits it perfectly and the carb comes with a very nice rubber seal already installed.
