Nice build, you did good!
One thing though, you don't have the heat shield spring around the clutch cable where it rests against the cylinder.
Simple to put on and needed ;-}
Otherwise sweet ride.
Thanks KC! Good eyes! Your have great attention to detail, I can tell from your very nice builds. I don't have no where near as many builds as you do (maybe some day) but of the four I've built and never used that spring all was ok.
As I'm sure you know there is metal inside that cable under the plastic cover. Since the cable is also metal not much can happen to cause a problem. I doubt that spring does much in the way of protecting against heat. Yeah it keeps it from touching it but with the little amount that does touch(with or with out the spring) and where it touches the motor there isn't enough heat to cause a problem IMO.
Try it out sometime. The first time I did it I checked it after and during every ride for the first couple hundred miles to make sure it was ok. The plastic never even melted on any of the builds. Thanks for looking out I really appreciate that.
However, if I (like you) was building bikes for customers, I would use the spring just so I would be 100% sure there wouldn't be any issues down the road.
