I've gathered a number of parts for this build, including a better tensioner than the ones that seem to come in the kits, specifically for that reason. Even the U-Bolts for the mounts I've seen online for mounting to a wider frame (the Chinese ones) look flimsy and unusually thin, so I've avoided that.
As for the brake coaster, I removed that and the bike presently has friction brakes. I intend to convert it to disc brakes, but first I want the engine sorted out. As for the rear sprocket not aligning, I didn't like the way that most people seem to mount their rear sprockets (with a system that clamps the rear sprocket to the rear wheel spokes, as per what apparently comes with the "kits" online) because it seemed to be a very flawed design. It is not only unsafe (especially with the Cranbrook's 14 gauge spokes) but it puts unnecessary stress on the spokes and allows for the rear sprocket to vibrate as well as move, causing wobble and lastly, it offers little to no means of adjusting the alignment of the rear sprocket. Instead, I contacted B&S Machine Tool (At
http://www.bsmachinetool.com/ ) and placed an order for an adapter that clamps around to the rear hub and holds a machined rear 36 tooth sprocket in place, similar to this one:
YesImLDS, I appreciate your offer, but even before my first post, I confirmed that the rear sprocket hasn't a thing to do with it. Even threading the chain through the engine's sprocket by hand, without attaching to the rear sprocket, it has the problem. It's definitely the sprocket on the engine. Just waiting for the tool to show up now, as to remove it... :/
