jared8783
I have gotten much better at connecting a bunch of little dot spot welds together without creating much warping, but the bead looks like a 3 year old welded it while wearing Scooby Doo sunglasses.
I really like my angle grinder and flap discs!
Man If I had to pick only one power cutting tool I could own it would be a 4.5" angle grinder. With some cutting wheels, grinding discs, and flap discs you would be surprised just how professional of a product you could make with that. I could easily modify a fresh chassis i from the ford factory into a motorhome chassis with tube steel with the only cutting tool being an angle grinder from start to finish and ready to paint. Time consuming vs big band saws cutting 50 tubes at once. Man I love me my angle grinders.
Keep in mind you can pull the wire back to drop the voltage to help fill gaps.
I've got two welders at home, a 115 harbor freight flux core mig, and a 230v 100 sec amp (whatever sec amps means) gas mig welder. Both are twenty percent duty cycle. I'm disatisified with both of them. But they function properly. I probably don't like them cause I'm used to 480v 3 phase 300 amp 100% duty cycle welders.
