KCvale
I love this combination of parts for a legal (in Arizona) reliable 'powerful enough' motorized bike for getting around as fast you want to go in style and comfort.
Specs:
2013 steel frame Macargi Pantera 7S 7-speed beach cruiser.
- 7-speed derailleur hub swapped for a Nexus 3-speed internal shifter.
- Front fork replaced with a telescoping shock fork with V and disc brake bosses.
- Bottom bracket replaced with SBP wider dual sprocket freewheel crank set.
- 3-speed shifter moved to left side and plastic throttle and left grips replaced with foam BMX style grips and independent V brakes.
2013 Gasbike.net HS 49cc 4-stroke engine with 2013 Grubee centrifugal clutch 4G belt drive transfer case kit.
- Chrome long exhaust.
2013 SBP 4-stroke shift kit mounting base and jackshaft hardware.
- Added a right side spring tensioner for easy chain maintenance.
Rain or shine, really slow (pace a jogger) or really fast (~40) it does the job much like a motorcycle does with gears and comfort.
The actual bike frame style with fenders and such aside, I like the power plant and drive train a lot, any frame with at least dual V brakes and if you can a shock front fork and you'll be a happy rider ;-}
			Specs:
