kdaddy1980
Ok guys, here we go again. Yesterday i went to ride my bike and it was really hard to start..then all the sudden it kicked in and ran good, but when i give it a good throttling it cuts out and wants to die. The engine revs really good without the clutch engaged but as soon as i engage the clutch it slows to a crawl and dies...
heres what ive tried so far
1) check the spark plug and wire
2) replaced the boot on the spark plug
3) checked and adjusted the clutch
4)checked the fuel bowl on the carb and it was ok (full of gas) but not overflowing i adjusted the float pin slightly tighter because i thought maybe it was flooding the engine.
5) checked the choke adjustment and its ok
6) found the intake loose and tightened it up.
7) checked and cleaned the air filter, took air filter off still same problem
8) verified that fuel was coming out of the gas tank
9) checked to see if i had a screw loose in my head lol
i just cant figure this one out guys..last time it was the exhaust clogged from using too much oil.. im going to take the exhaust completely off again and see if maybe i missed a chunk of debris in it or something but it seems like theres no restriction.
let me know what you guys think or if you had the same problem Thanks
off road ,in the grass...i even took it mudding one time, but that just clogged the gears up with mud
haha do you guys think if i just baby the next one i can get more than 1100 miles out of it before any major work needs to be done?
