Do we need a " belt driven" thread?
Moto pope
It may not have enough interest, but just wonder if it would be of help. I planned my current (which is also my first) project to Be a belt drive, but decided to go chain when I couldn't find enough info. I've since learned of this forum and the search capabilities, but it would have helped to have em all in one.spot. Btw, my next build will be belt drive.
need?
well, maybe...
Build some activity in a thread....
Take a tip, Leave a tip has a life of it's own, as does What did you do to your motorbike today?....
Start a Belt Drive Only thread with a good information base and it could very easily take off.
I think belt drive is a fine drive method at this horsepower level and there are great possibilities with the toothed-belts, also... at least one bicycle uses a belt. Trek???
Good luck
rc
It sounds like a good idea. I believe there's at least four or five bikes on here that uses just a belt drive; whether it be direct off the engine or through a jackshaft. I know that user dsmith has a very nice setup and I pretty much copied his for mine and am planning on redoing it on a different frame with a lever controlled tensioner instead of the foot pedal. Belt drive is probably the best choice for a drive system for people that don't want to spend a lot on some kind of chain drive or don't want a friction drive; so for people like that there is a lot of information to be wanted and to be given by the people that already have it.
Whizzers are belt driven, always have been.
Ray
My original, and most compelling, interest in "belt drive" centers in the vintage look/style the system gives to a project Most of the bikes which have served as inspiriation (1910-1920) use belts. My guess is that a primitive technology in roller chain,at the time, was the driving force behind the belts use in those early machines. Anyhow, I am certainly not too proud to learn from other peoples experience (i. e. mistakes ???) as I make my own.
We may have more members installing Briggs style motors if the belt drive info was easy to find. The belt drive is the simplest way to install the bigger motors because a big sheave eliminates the need for a jackshaft and a hand operated belt tensioner eliminates the need for a clutch.
With most engines a jackshaft is still necessary to get a low enough gear reduction, and also necessary for alignment without offsetting the engine. Maybe a single primary belt setup could work with Briggs and similar engines, but I've never seen it done.
Mr. B has done all that on his Excalibur. I've learned a lot studying his build thread, pretty good instruction.
If you want to look at some bikes to get some ideas for belt drive if suggest looking at fellow member "MSRFAN" bikes. He helped me a lot with advice to get my belt drive bike up and running.
Were you addressing me then? Do you mean the single belt drive setup? If so doesn't he have a jackshaft and primary and secondary belts?....... Mr B's Excalibur is a beautiful bike and IMO the best bike on this site. I love it!!!!
I would like to build the Tecumseh Fat Bike with belt drive, but I'm hesitant for what I have perceived to be a lack of info.
Yea.
I am available to answer any questions I am able to about belt driven bikes. I built a bike with a briggs motor, belt primary, and belt secondary, with a cvt clutch and jackshaft. The name of my build thread is "Roadmaster Project" I learned a lot from msrfan as well, he's very helpful.
Its pretty simple to do. The most fiddly thing was determining the correct size belts. They are measured a funny way (to me) and it took a while to figure out just the right size.
Anyone who seeks information can contact me through PM or on this thread.
Gilbert
I'm also planning to do a belt drive, so am signing on to this thread. How about providing links to builds using belt drive? Harry 76's Villiars build gives a lot of good information... Mr. B, all of the Briggs builds. There are probably others as well.
SB
Here's a link to mine. Its a long thread and not a lot of specific belt related stuff, but like I said, I can answer questions or take more detailed pictures.
One of msrfan's bikes. Here
Another msrfan bike. Here
I forgot! Otero has done this, and even gave me a little guidance on assembly. Thanks Otero!
This idea struck me a while ago and I started getting some general info together, then got busy with my chain drive.
Has anyone seen the Gates Belt system yet? Looks to me like you'd get by with a skinnier belt for the same drive capability.
Yes.
This is the Trek District.
Trek also make a Soho model that is multi-speed.
...just under a grand, list price. Not sure of the street price.
rc
