24: 1 for the first gallon, 32: 1 after that, unless you're using specialty oil like Opti2 or a synthetic.
I took a chance Sunday, and broke in my latest 66cc build with 40-1 Pennzoil.
Upon first start, I immediatly went to WOT, but I let off at about 10mph, coasted down real slow an full bore to 10 mph or so, for a couple munites to warm it up good.
Then I flogged it hard, up and down a 1/2 mile hill, over and over for one hour, no cooldown except for taking it easy on the downhiill run the first 5 or 6 runs .
I did keep the stock slightly rich 4 stroking original clip positon during break-in.
After 3 one hour sessions, I dropped the needle one notch and it runs perfect now. Good plug read and very, very slight 4 stroking at WOT.
I figure if I hear a little 4 stroking, i'm not too lean.
Gonna change to 50/1 after a few more hours use.
Heat cycling is not required for a good break-in with these engines.
These things aint so delicate, as long as the fuel/air mix isn't too lean.
I'll keep yall posted
Maybe you should read our rules regarding respect for others> http://motorbicycling.com/showthread.php?t=2Didn't mean to bash anybody. Just offered my take on the advice given by Wayne. I think the moderator is too trigger happy but whatever. There is a lot of different and often conflicting advice offered here on a lot of things and if you're a newbie like me you can end up following bad advice and ruin your cylinder like I did. And btw, that is NOT an opinion about proper break in and what Wayne did to his motor is GUARANTEED to scar the cylinder and blow compression. Then you'll be mad at him, not me. Worse, the manual that comes in the box tells you very little about proper break in. Then what do you do? You just voided the warranty and have a 25 lb. paperweight.
There are kits with warranties ??!!??
which ones?
