Recently I have noticed a loss of power in the mid to high end prm range. Checklist of repairs done so far. ( did each repair seperatly with test rides between each.
burned ignition wires. replaced wiring with new and soldered conections.
ALL motor nuts and bolts tightened to proper torque.
carb cleaned and reasembled properly (thanks Norm for such detailed instructions)
needle set at stock location, second notch from top.
no air leaks.
new plug and wire.
fuel mixed @ 40:1
While looking at everything slightly disassembled I noticed scoring in the cylinder bore, could be from bad rings?
Also, the head gasket is slightly out of shape, inside diameter the edge of metal gasket is bent up a bit. could this cause a loss of comprestion?
Sorr, no pics at the moment?
no air leaks.
new plug and wire.
fuel mixed @ 40:1
