Mine did that before (stall when giving it throttle). It turned out to be an air leak between the carb and manifold tube. Putting the rubber o-ring in there cured it.
I have the CNS V2 crab. I got rid of the plastic spacer and made one out of copper. I have been playing with the floats a little. Right now my floats hit the bottom of bowl. If I pull the floats higher, the crab doesn't get gas and it won't start. thanksMine did that before (stall when giving it throttle). It turned out to be an air leak between the carb and manifold tube. Putting the rubber o-ring in there cured it.
You are probably right. Every thing eles on this kit doesn't works right or needs to be change. I think this needs to be recommend to everyone who gets the CNS carb. ThanksYou might need a new 10 cent rubber seal. That's exactly what I needed When I came across this problem
Thanks, I check the screen and it was very dirty. I guess I should had clean the tank. I just look inside the tank and since it look clean, I left it like that. But it is never clean. Everything inside, starts to fall apart.Maybe the screen in the tank is clogged up?
Thank you, Iam going to have to order a better gas switch. Whats a tank sealer. ThanksEmpty the tank, take the tank off, and remove the petcock. Take it to a coin-operated car wash or use a pressure washer, and blast all that crap out of there. Let it sun dry for a day. Install a tank sealer if you use one, and use a petcock from Sick Bike Parts (best) or go to a boat shop or MC shop and find one.
