yah, I think. Is a complete rebuild kit pistons, rings, bearings, seals and pumps about $ 250. too good to be true ......?
Thanks Al,but I really need the plastic reducer ring and that kit doesn't look like its got one.I tried to make one and it didn't work big air leak.
Thanks nightcruiser,
I read your post on the cns tuning.Now I think I have a float valve(needle) sticking which is the problem,I'm going to order the rebuild kit from gasbike.I also need the plastic reducer or spacer what ever its called.Thanks every body too.
Thanks nightcruiser
I just got done making spacer from your post.I got the valve working too.So if it all works thanks.I'll try it Monday got a bunch of stuff to do around here.I will let all you guys know when I try it out.
