Remember the two screws are for idle only, if you can adjust the idle thats all they do. The e-clip controls mid range and the main jet size controls full throttle. The cns has a idle jet also.
The screw close to the air filter is the idle mixture screw. If you take the carb apart you can see the hole behind the filter element and the small hole in the throat of the carb.
I still cannot get my bike to run right. I got a SBP muffler on it now. And it runs very good for about 5 or 10 minutes when I first start it. And then it loses all of it power, when I press the gas for the bike to go. What could cause this? Thanks![]()
If you are using the trash-can tank with the happytime, you must ditch the in-tank filter screen and chinese petcock. You can get a 10mm brass fitting with a 1/4" barb, and a $5 in-line fuel shutoff, and a $3 inline fuel filter. You should be all set, and if not, it will save you some pedaling down the road.
Hi Hose13; sounds like the engine is running out of gas when you twist the throttle and add a load to the engine. Check for adequate fuel flow to the carb. Also, you might want to try and move the main needle in the carb up a notch to richen the fuel mixture. I doubt that your problem is of a serious nature. BMF
