taddthewadd
The wider chain (41) can make up for a slight difference in the engine and rear sprocket not being in perfect alignment. Since it is wider, it will not have a tendency to derail from the sprocket not being in perfect alignment unlike the stock 415 chain that is narrower, it will derail much easier if the sprocket is not aligned. I had the same problem with my 415 chain, it literally shatered while riding at about 15mph. I have since changed to 41 chain from tractor supply and it runs much smoother now. Hope this info can help you out.
You took the words out of my mouth. I used the 415 and when I walks the bike beside me without the engine running the chain "popped" and made funny noises and when I put the #41 it is very smooth and the chain line looks perfect.
