Ive read through it all in 1 week
this is the sum of all these posts
upjet, check needle, check float, adjust air screw
well I had to down jet came way to rich, im at sea level
adjusted needle leaner
float checked out correctly how it came,carb also sits dead level on the intake
no mention of what to do with the hoses, ive read capped, taken out from somewhere I cant remember
all I know is to have a hose on the bowl, and on the vent
the 2 other nipples I have no idea what to do
didnt really see much about idle im just surprised how bad it idles when cold
the stock carb barely needed choke for the first 10 seconds after that none
Thanks for going over all this info guys. I'm getting close to starting up my second MaB build, and just when I thought I knew how to tune the CNS carb, this second engine came with an updated CNS carb that has the extra hoses, and no needle slots to adjust the mixture with. I hope it all goes smoothly and I get it right without too much messing around.
I'll give this one a try first, and keep my fingers crossed hoping it works right. The needle looks the same, but I didn't measure it so I don't know if the rebuild kit one would work or not. Its a good idea though, thanks for bringing it up.
Biknut, sorry I was not clear on my jet size. Mine is at a #64 drill bit, I drilled it out with a 69 first then one size larger till I got the plug color that I wanted. With a stock air filter and the restrictive air flow the 69 was fairly good.
I'm not clear how that works.
Pls explain...
#64 is larger than a #69. It's got a bigger hole, allows more fuel.
In order to take a #64 to a #69, IMO, it would be necessary to first solder the jet, before drilling.
Or did I miss something...
Best
rc
nightcruiser ... this new CNS carb has just the one adjusting screw. The second one closest to the air filter is capped off.
Cool, that's the new one I guess... I'd be interested to hear how it works out for ya...
