Boy Go fast Customer Service ?
heretolearn
I sent an email to to boygofast customer service regarding 80cc engine [email protected] and explained with pictures and words saying that the nut that goes under the clutch plate kept coming loose and that the slot behind the washer was empty with no wood ruff key. I sent him pictures showing the problem and he sent me an email with pictures with a hammer saying to hit the plate in the middle ? I dont think that sounds right. Below is the email he sent explaining.
Clutch adjustment:
Please open the clutch cover ( which is 5 bolts attached)
Turn the middle of the flower nut right or left to make it tighten or loose.
Or
Some time the curve on the plate is not deep enough. So hit the middle of the plate to make it little deeper (about 1-2mm), then adjust the flower nut. ( this not happen usually, but in case)
I attach few pictures, u can take a look
and also please check the flower nut if thread no good
If you have any question, feel free to email us
thanks
BGF:-||
Yeah, just whack the thing with a big 2 pound ball peen.
Keep whacking until it works.
That's the China way.
Giving it a good whack to the clutch plate really works and is the right fix. Only need about 2'pounds of force.
there has to be a key in the shaft or the clutch unit would just spin on the shaft. how could it even start without the shaft keyed to the clutch.
Gosh.
That's kinda pretty good customer service!
Instruction for the fix!
Whackin' parts and pieces with a basher is called "fitment". :-)
Yah, there may be a woodruff key missing from original build, and if the clutch hub nut is loosening, perhaps there should be a star washer behind it??? I can't recall, but it should show in my pics, or in Lord Vader's clutch pics. (an interference fit of a hub on a tapered shaft is not really extra-ordinary, and a keyway is generally used where the transmission of power must be precisely indexed. In this application, it's not... in a timing rotor, it is.)
(Yet if the machining is marginal, the fitment should be lapped, or a key used.)
a bit of loctite on that thread would probably be a good idea. the machining may be mis-matched in tolerances between the thread and the nut causing it to loosen up.
Good luck
rc
I confirmed it is missing woodruff key Thanks to you guys and I'm gonna email them and tell them I would like to send it back to be repaired by them. Does anyone have an Idea how that might go over?
Customer service by my experience LACKING. You'd most likely be better off installing a key yourself.
Ricky Shu just shuffles boxes of parts around. You send him a motor you will get another one back. He can play you along until the dispute period is over with eBay. I had to go into extended dispute with him when he simply should have replaced it from the first. He doesn't care about individuals, he just moves product as fast as possible.
I wasted most of a riding season cause of this swinging Richard. Dispute the sale as not as described(a running working motor) and get another motor.
And there should be NO reason for that. Like I've said before....I wouldn't buy so much as a washer from them (BGF/luckyearlybird). If I had to resort to buying from them, I'd scrap my bike.
Yeah Big ten on that, I wish I would have known about this site I would have asked where to buy from. I paid $188.00 for the 80cc kit and I hear for a few more bucks I could have gotten a better kit some where else.
I guess you didn't get here to learn fast enough :>)
You mean you are not going to fix it with the hammer as advised?
If you pound on the shaft enough it will eventually expand enough to grab the clutch.
But probabily not before you drive it right through the motor - :)
I still can't believe he sent you a pic of a big ball peen. Too funny - laff
If it were me I would try replacing the key first, seems like a-lot of trouble to remove and ship the engine for a 2$ part. Most hardware or auto parts stores should have keys.
HELP I ordered a pull start for my 80cc It arrived with NO instructions I found this thing would not attach without binding to the magneto holding screws I removed the washers under these screws,it gave enough clearance for the part to spin freely (the spinner part that bolts to the magneto shaft) Now I find that the nut that holds the spinner has very little thread holding it on(very scary) Has anyone any suggestions before I ruin the motor Gerry
